Problems with SBL on FTD with Secure Client
User42
Hi together
We had the following Setup: ASA with Anyconnect (Always on and SBL)
This worked quite well (VPN gets establised before Login)
Now we upgraded to FTD with Anyconnect (Always on and SBL)
The Anyconnect now waits until the Edge Browser gets loaded before the he establish the VPN tunnel.
As we switched back to the ASA we had the same Problem there.
We now upgraded to Secure Client.
But it still won't work. (It waits until edge gets started)
Workaround for now: Start the VPN before login manually
But we would really appricate a better solution.
Has anybody an idea?
Thanks in advance!
0 Replies 0
