10-21-2010 03:49 AM
hi folks,
how to block or deny in cisco asa 55XX series firewall, received an ARP packet
Received ARP message which contains an ARP collision
thanks in advance,
regards
bashah
10-21-2010 06:18 AM
You can find details about the syslog you are getting at the below link:
http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi?action=search&locale=en&index=all&query=ASA-4-405001&counter=0&paging=5&links=reference&sa=Submit
You will want to have a look at where exactly those packets are coming from. there isn't a way to block it on the ASAin routed mode unfortunately. In Transparent mode, you can using the following feature:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/bridgarp.html#wp1039837
Let me know how it goes!
regards,
Prapanch
Log in to Community
