remote console connection help
rwawrig
Level 3
Level 3
Sorry if my topic is not fitting in this section...but I need some help in finding an equipment.
I need to connect to this equipment remotely, via IP, and then from there to connect via serial connection into console port of a cisco router.
So, this equipment should have 3,6 serial ports where I can connect the console ports of my equipments for console management purpose.
Is there a cisco equipment designed for this ? Or from another vendor ?
Robert
cmbarton78
Community Member
Try the 2500 series. You can configure them as terminal servers and can choose from models w/8 async ports or 16. I'm currently working on the AS2509-RJ. There are several documents on line to help w/setting it up. Here's a site to get you started.
http://www.cisco.com/warp/public/793/access_dial/comm_server.html
hope this helps.
christina
cmbarton78
Community Member
hope this helps.
christina
This should work. Thanks for the info.
Robert
