Routing Problem between VPN Client and Router's Ethernet Device
thomas.schmidt
i have here a Cisco 1721 in a test environment.
A 172.16.0.0/19 net simulates the Internet and a 192.168.1.0/24 net simulates the Net, the VPN tunnel should go to (intranet).
The 172.16.0.0 net hangs on router's FastEthernet 0, the (VPN)Intranet hangs on Ethernet 0.
The configuration was inspired form the Configuration example
"Configuring Cisco VPN Client 3.x for Windows to IOS Using Local Extended Authentication"
and the ConfigMaker's configuration output.
Authentication and logon works. Client gets an IP from pool. But there is a routing problem
on routers side. Ping from client side - dont work (In VPN client statistics the encrypt packets count up, but no decrypt).
Ping from router dont work too, but decrypt and encrypt packets in VPN client's statistics counts up
(the client has a correct route and returns ICMP packets to router).
The questions is now:
How to route packets between the Tunnel and an Ethernet (Ethernet 0) device ?
router's conf is attached - hope that's not too much ...
thanks && regards
Thomas Schmidt
-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.- snipp .-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname **moderator edit**
enable secret 5 **moderator edit**
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
! only for test ...
username cisco password 0 **moderator edit**
ip subnet-zero
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
encryption 3des
authentication pre-share
group 2
crypto isakmp client configuration group 3000client
key cisco123
pool ippool
! we dont want to split tunnel
! acl 108
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Ethernet0
no shutdown
description connected to VPN
full-duplex
ip access-group 101 in
ip access-group 101 out
keepalive 10
no cdp enable
interface Ethernet1
no shutdown
ip address 192.168.3.1 255.255.255.0
full-duplex
keepalive 10
no cdp enable
interface FastEthernet0
no shutdown
description connected to Internet
ip address 172.16.12.20 255.255.224.0
speed auto
keepalive 10
no cdp enable
! this access group is also only for test case !!!!
no access-list 101
access-list 101 permit ip any any
ip local pool ippool 192.168.10.1 192.168.10.10
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.12.20
ip pim bidir-enable
line con 0
exec-timeout 0 0
password 7 **moderator edit**
line aux 0
line vty 0 4
end
^-^-^-^-^-^-^-^-^-^-^-^-^- snapp ^-^-^-^-^-^-^-^-^-^-^-^-^-^-
kdurrett
Level 3
Level 3
Thomas,
Hate to point out something that might be there, but I dont see it here. You dont have the crypto map applied to any of the interfaces, maybe it didnt get copied. Assuming from your description you have it, or should have it, applied to fa0 and you get connected. How are you trying to ping? From the router or a device located on E0? If you pinging from the router, you will need to do a extended ping from E0 to the ip the client was assigned. If your just pinging from the router without doing the extended, you will get encrypts and decrypts as you are stating on the client. Did you try pinging from the client to E0 interface? Your default route on the router is pointing to fa0? Do you have a next hop to assign? Do you have multiple NIC's on the client pc? Disable your other nics to verify you dont have some routing issue on the client if you have more than one.
Kurtis Durrett
kdurrett
Level 3
Level 3
Thomas,
Kurtis Durrett
Hello Kurtis,
yeah the crypto map applied entry seems to be cuted while coping the conf from router to MUA - sorry. Your hints helped me a lot - thanks. (didn't know that there is an advanced ping/traceroute ...). My suspicion was right that the problem was a missing routing directive on the router - everything else was OK.
added simply a route (ip route 192.168.10.0 255.255.255.0 fe0 ) - and everything work ... - sorry to ask you with such a simple question ;-)
regards
Thomas
