S2S between Cisco ASA 5505 and Sonicwall TZ-170 but not able to ping across
Scott Fares
I am helping out a friend of mine with his Site-to-Site VPN between his companies Cisco ASA another company's SonicWall TZ-170.  I have checked the screenshots proivded by the other end and tried to match with ours.  The Tunnel shows but we are not able to Ping resources on the other end.  The other side insists that the problem is on our end but I am not sure where the issue resides.  Please take a look at our config and let me know if there is anything that I have missed.  I am pretty sure I didn't but extra eyes may be of need here.
Our LAN is 10.200.x.x /16 and theirs is 192.168.9.0 /24
ASA Version 8.2(2)
terminal width 300
hostname company-asa
domain-name Company.com
no names
name 10.1.0.0 sacramento-network
name 10.3.0.0 irvine-network
name 10.2.0.0 portland-network
name x.x.x.x MailLive
name 192.168.9.0 revit-vpn-remote-subnet
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.128
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.200.200.1 255.255.0.0
interface Ethernet0/2
nameif dmz
security-level 50
ip address 172.22.22.1 255.255.255.0
interface Ethernet0/3
description Internal Wireless
shutdown
nameif Wireless
security-level 100
ip address 10.201.201.1 255.255.255.0
interface Management0/0
shutdown
nameif management
security-level 100
no ip address
management-only
boot system disk0:/asa822-k8.bin
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
domain-name company.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network local_net_group
network-object 10.1.0.0 255.255.0.0
network-object 10.2.0.0 255.255.0.0
network-object 10.200.0.0 255.255.0.0
network-object 10.3.0.0 255.255.0.0
network-object 10.4.0.0 255.255.0.0
network-object 10.5.0.0 255.255.0.0
network-object 10.6.0.0 255.255.0.0
network-object 10.7.0.0 255.255.0.0
network-object 192.168.200.0 255.255.255.0
object-group network NACIO123
network-object 1.1.1.1 255.255.255.224
object-group service MAIL_HTTPS_BORDERWARE tcp
port-object eq smtp
port-object eq https
port-object eq 10101
object-group service SYSLOG_SNMP_NETFLOW udp
port-object eq syslog
port-object eq snmp
port-object eq 2055
object-group service HTTP_HTTPS tcp
port-object eq www
object-group network OUTSIDECO_SERVERS
network-object host x.x.x.34
network-object host x.x.x.201
network-object host x.x.x.63
object-group network NO-LOG
network-object host 10.200.200.13
network-object host 10.200.200.25
network-object host 10.200.200.32
object-group service iPhoneSync-Services-TCP tcp
port-object eq 993
port-object eq 990
port-object eq 998
port-object eq 5678
port-object eq 5721
port-object eq 26675
object-group service termserv tcp
description terminal services
port-object eq 3389
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DTI tcp
description DCS CONTROL PROTOCOL
port-object eq 3333
object-group service H.245 tcp
description h.245 signaling
port-object range 1024 4999
object-group service RAS udp
port-object eq 1719
port-object range 1718 1720
object-group service XML tcp
port-object range 3336 3341
object-group service mpi tcp
port-object eq 2010
object-group service mvp_control tcp
port-object eq 2946
object-group service rpc tcp-udp
port-object eq 1809
object-group service tcp8080 tcp
port-object eq 8080
object-group service tcp8011 tcp
port-object eq 8011
object-group service rtp_rtcp_udp udp
port-object range 1024 65535
object-group service ecs_xml tcp-udp
port-object eq 3271
object-group service rtp20000 udp
description 10000-65535
port-object range 20000 25000
port-object range 10000 65535
object-group service tcp5222 tcp
port-object range 5222 5269
object-group service tcp7070 tcp
port-object eq 7070
object-group network videoco
network-object host x.x.x.144
network-object host x.x.x.145
object-group service video tcp
port-object range 1718 h323
object-group service XML2 tcp-udp
port-object range 3336 3345
object-group service tcp_tls tcp
port-object eq 5061
object-group service Autodesk tcp
port-object eq 2080
port-object range 27000 27009
access-list outside_policy remark ====== Begin Mail From Postini Network ======
access-list outside_policy extended permit tcp x.x.x.x 255.255.240.0 host x.x.x.x eq smtp
access-list outside_policy extended permit tcp x.x.x.x 255.255.255.240 host x.x.x.x eq smtp
access-list outside_policy extended permit tcp x.x.x.0 255.255.240.0 host x.x.x.x eq smtp
access-list outside_policy remark ****** End Mail From Postini Network ******
access-list outside_policy remark ====== Begin Inbound Web Mail Access ======
access-list outside_policy extended permit tcp any host x.x.x.x object-group HTTP_HTTPS
access-list outside_policy remark ****** End Inbound Web Mail Access ******
access-list outside_policy remark ====== Begin iPhone Sync Rules to Mail Server ======
access-list outside_policy extended permit tcp any host x.x.x.x object-group iPhoneSync-Services-TCP
access-list outside_policy remark ****** End iPhone Sync Rules to Mail Server ******
access-list outside_policy remark ====== Begin MARS Monitoring ======
access-list outside_policy extended permit udp x.x.x.x 255.255.255.128 host x.x.x.x object-group SYSLOG_SNMP_NETFLOW
access-list outside_policy extended permit icmp x.x.x.x 255.255.255.128 host x.x.x.x
access-list outside_policy remark ****** End MARS Monitoring ******
access-list outside_policy extended permit tcp object-group NACIO123 host x.x.x.141 eq ssh
access-list outside_policy extended permit tcp any host x.x.x.x eq www
access-list outside_policy extended permit tcp any host x.x.x.x eq https
access-list outside_policy extended permit tcp any host x.x.x.x eq h323
access-list outside_policy extended permit tcp any host x.x.x.x range 60000 60001
access-list outside_policy extended permit udp any host x.x.x.x range 60000 60007
access-list outside_policy remark radvision 5110   port 80 both
access-list outside_policy extended permit object-group TCPUDP any object-group videoco eq www
access-list outside_policy extended permit tcp any object-group videoco object-group termserv
access-list outside_policy remark radvision 5110  port21 out
access-list outside_policy extended permit tcp any object-group videoco eq ftp
access-list outside_policy remark rad5110   port22 both
access-list outside_policy extended permit tcp any object-group videoco eq ssh
access-list outside_policy remark rad 5110  port161 udp both
access-list outside_policy extended permit udp any object-group videoco eq snmp
access-list outside_policy remark rad5110 port443 both
access-list outside_policy extended permit tcp any object-group videoco eq https
access-list outside_policy remark rad5110 port 1024-4999  both
access-list outside_policy extended permit tcp any object-group videoco object-group H.245
access-list outside_policy remark rad5110 port 1719 udp both
access-list outside_policy extended permit udp any object-group videoco object-group RAS
access-list outside_policy remark rad5110 port 1720 both
access-list outside_policy extended permit tcp any any eq h323
access-list outside_policy remark RAD 5110 port 3333 tcp both
access-list outside_policy extended permit tcp any object-group videoco object-group DTI
access-list outside_policy remark rad5110 port 3336-3341 both
access-list outside_policy extended permit object-group TCPUDP any object-group videoco object-group XML2
access-list outside_policy remark port 5060 tcp/udp
access-list outside_policy extended permit object-group TCPUDP any object-group videoco eq sip
access-list outside_policy remark rad 5110port 1809 rpc both
access-list outside_policy extended permit object-group TCPUDP any object-group videoco object-group rpc
access-list outside_policy remark rad 5110 port 2010 both
access-list outside_policy extended permit tcp any object-group videoco object-group mpi
access-list outside_policy remark rad 5110 port 2946 both
access-list outside_policy extended permit tcp any object-group videoco object-group mvp_control
access-list outside_policy extended permit tcp any object-group videoco object-group tcp8080
access-list outside_policy extended permit tcp any object-group videoco object-group tcp8011
access-list outside_policy remark 1024-65535
access-list outside_policy extended permit udp any object-group videoco object-group rtp_rtcp_udp
access-list outside_policy extended permit object-group TCPUDP any object-group videoco object-group ecs_xml
access-list outside_policy extended permit udp any object-group videoco object-group rtp20000
access-list outside_policy extended permit tcp any object-group videoco eq telnet
access-list outside_policy remark port 53 dns
access-list outside_policy extended permit object-group TCPUDP any object-group videoco eq domain
access-list outside_policy remark 7070
access-list outside_policy extended permit tcp any object-group videoco object-group tcp7070
access-list outside_policy remark 5222-5269 tcp
access-list outside_policy extended permit tcp any object-group videoco range 5222 5269
access-list outside_policy extended permit tcp any object-group videoco object-group video
access-list outside_policy extended permit tcp any object-group videoco object-group tcp_tls
access-list outside_policy remark ====== Begin Autodesk Activation access ======
access-list outside_policy extended permit tcp any any object-group Autodesk
access-list outside_policy remark ****** End Autodesk Activation access ******
access-list outside_policy extended permit tcp x.x.x.x 255.255.255.248 host x.x.x.x eq smtp
access-list inside_policy extended deny tcp host 10.200.200.25 10.1.0.0 255.255.0.0 eq 2967 log disable
access-list inside_policy extended deny tcp host 10.200.200.25 10.3.0.0 255.255.0.0 eq 2967 log disable
access-list inside_policy extended deny tcp host 10.200.200.25 10.2.0.0 255.255.0.0 eq 2967 log disable
access-list inside_policy extended deny tcp host 10.200.200.25 10.4.0.0 255.255.0.0 eq 2967 log disable
access-list inside_policy extended deny tcp host 10.200.200.25 10.5.0.0 255.255.0.0 eq 2967 log disable
access-list inside_policy extended deny udp object-group NO-LOG any eq 2967 log disable
access-list inside_policy extended deny tcp object-group NO-LOG any eq 2967 log disable
access-list inside_policy remark ====== Begin Outbound Mail Server Rules ======
access-list inside_policy extended permit udp host 10.200.200.222 any eq 5679
access-list inside_policy extended permit tcp host 10.200.200.222 any eq smtp
access-list inside_policy remark ****** End Outbound Mail Server Rules ******
access-list inside_policy extended permit ip object-group local_net_group any
access-list inside_policy extended permit icmp object-group local_net_group any
access-list OUTSIDECO_VPN extended permit ip host x.x.x.x object-group OUTSIDECO_SERVERS
access-list company-split-tunnel standard permit 10.1.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.2.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.3.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.4.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.200.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.5.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.6.0.0 255.255.0.0
access-list company-split-tunnel standard permit 10.7.0.0 255.255.0.0
access-list company-split-tunnel standard permit 172.22.22.0 255.255.255.0
access-list company-split-tunnel remark Video
access-list company-split-tunnel standard permit 192.168.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.1.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.2.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.3.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.200.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.4.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.5.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.6.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 10.7.0.0 255.255.0.0
access-list SSL_SPLIT standard permit 172.22.22.0 255.255.255.0
access-list SSL_SPLIT remark Video
access-list SSL_SPLIT standard permit 192.168.0.0 255.255.0.0
access-list NONAT_SSL extended permit ip object-group local_net_group 172.20.20.0 255.255.255.0
access-list NONAT_SSL extended permit ip 10.200.0.0 255.255.0.0 192.168.9.0 255.255.255.0
access-list tom extended permit tcp host x.x.x.x any eq smtp
access-list tom extended permit tcp host 10.200.200.222 any eq smtp
access-list tom extended permit tcp any host x.x.x.x
access-list aaron extended permit tcp any any eq 2967
access-list capauth extended permit ip host 10.200.200.1 host 10.200.200.220
access-list capauth extended permit ip host 10.200.200.220 host 10.200.200.1
access-list DMZ extended permit icmp any any
access-list dmz_access_in extended permit tcp any eq 51024 any eq 3336
access-list dmz_access_in extended permit icmp any any
access-list dmz_access_in extended permit tcp any any eq ftp
access-list dmz_access_in extended permit tcp any any eq https
access-list dmz_access_in remark rad5110 port 162 out
access-list dmz_access_in extended permit udp any any eq snmptrap
access-list dmz_access_in remark port 23 out
access-list dmz_access_in extended permit tcp any any eq telnet
access-list dmz_access_in remark port 53 dns out
access-list dmz_access_in extended permit object-group TCPUDP any any eq domain
access-list dmz_access_in extended permit object-group TCPUDP any any eq www
access-list dmz_access_in extended permit tcp any any eq h323
access-list dmz_access_in extended permit tcp any any object-group XML
access-list dmz_access_in extended permit udp any any object-group RAS
access-list dmz_access_in extended permit tcp any any range 1718 h323
access-list dmz_access_in extended permit tcp any any object-group H.245
access-list dmz_access_in extended permit object-group TCPUDP any any eq sip
access-list dmz_access_in extended permit udp any any object-group rtp_rtcp_udp
access-list dmz_access_in extended permit object-group TCPUDP any any object-group XML2
access-list dmz_access_in extended permit ip object-group local_net_group any
access-list dmz_access_in remark port 5061
access-list dmz_access_in extended permit tcp any any object-group tcp_tls
access-list outside_cryptomap extended permit ip 10.200.0.0 255.255.0.0 192.168.9.0 255.255.255.0
pager lines 24
logging enable
logging buffered warnings
logging trap informational
logging history informational
logging asdm warnings
logging host outside x.x.x.x
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu Wireless 1500
mtu management 1500
ip local pool SSL_VPN_POOL 172.20.20.1-172.20.20.75 mask 255.255.255.0
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT_SSL
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) x.x.x.12 10.200.200.15 netmask 255.255.255.255
static (inside,outside) x.x.x.15 10.5.0.11 netmask 255.255.255.255
static (inside,outside) x.x.x.13 10.200.200.240 netmask 255.255.255.255
static (inside,outside) x.x.x.16 10.200.200.222 netmask 255.255.255.255
static (inside,outside) x.x.x.14 10.200.200.155 netmask 255.255.255.255
static (inside,dmz) 10.200.200.0 10.200.200.0 netmask 255.255.255.0
static (inside,dmz) 10.4.0.0 10.4.0.0 netmask 255.255.0.0
static (dmz,outside) x.x.x.18 172.22.22.15 netmask 255.255.255.255
static (dmz,outside) x.x.x.19 172.22.22.16 netmask 255.255.255.255
static (inside,dmz) 10.3.0.0 10.3.0.0 netmask 255.255.0.0
static (inside,dmz) 10.2.0.0 10.2.0.0 netmask 255.255.0.0
static (inside,dmz) 10.1.0.0 10.1.0.0 netmask 255.255.0.0
static (inside,dmz) 10.6.0.0 10.6.0.0 netmask 255.255.0.0
static (inside,dmz) 10.7.0.0 10.7.0.0 netmask 255.255.0.0
static (inside,dmz) 10.5.0.0 10.5.0.0 netmask 255.255.0.0
access-group outside_policy in interface outside
access-group inside_policy in interface inside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 x.x.x.12 1
route inside 10.1.0.0 255.255.0.0 10.200.200.254 1
route inside 10.2.0.0 255.255.0.0 10.200.200.254 1
route inside 10.3.0.0 255.255.0.0 10.200.200.254 1
route inside 10.4.0.0 255.255.0.0 10.200.200.254 1
route inside 10.5.0.0 255.255.0.0 10.200.200.254 1
route inside 10.6.0.0 255.255.0.0 10.200.200.254 1
route inside 10.7.0.0 255.255.0.0 10.200.200.150 1
route inside x.x.x.0 255.255.255.0 10.200.200.2 1
route inside 192.168.1.0 255.255.255.0 10.200.200.254 1
route inside 192.168.2.0 255.255.255.0 10.200.200.254 1
route inside 192.168.3.0 255.255.255.0 10.200.200.254 1
route inside 192.168.4.0 255.255.255.0 10.200.200.254 1
route inside 192.168.5.0 255.255.255.0 10.200.200.254 1
route inside 192.168.6.0 255.255.255.0 10.200.200.254 1
route inside 192.168.7.0 255.255.255.0 10.200.200.254 1
route inside 192.168.200.0 255.255.255.0 10.200.200.254 1
route inside 192.168.201.0 255.255.255.0 10.200.200.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 2:00:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server COMPANY-NT-AUTH protocol nt
aaa-server COMPANY-NT-AUTH (inside) host 10.200.200.220
nt-auth-domain-controller DC
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
http server enable
http 10.200.200.0 255.255.255.0 inside
http 10.200.0.0 255.255.0.0 inside
http 10.3.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set AES256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set asa2transform esp-3des esp-sha-hmac
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set transform-set 3DES-SHA
crypto dynamic-map outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto map OUTSIDE_MAP 5 match address outside_cryptomap
crypto map OUTSIDE_MAP 5 set pfs
crypto map OUTSIDE_MAP 5 set peer x.x.x.53
crypto map OUTSIDE_MAP 5 set transform-set 3DES-SHA
crypto map OUTSIDE_MAP 5 set security-association lifetime seconds 28800
crypto map OUTSIDE_MAP 10 match address OUTSIDECO_VPN
crypto map OUTSIDE_MAP 10 set peer x.x.x.25
crypto map OUTSIDE_MAP 10 set transform-set AES256-SHA
crypto map OUTSIDE_MAP 10 set security-association lifetime seconds 28800
crypto map OUTSIDE_MAP 10 set security-association lifetime kilobytes 4608000
crypto map OUTSIDE_MAP 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map OUTSIDE_MAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 20
console timeout 0
dhcpd dns 10.200.200.220 10.200.200.225
dhcpd wins 10.200.200.220 10.200.200.225
dhcpd lease 18000
dhcpd domain company.com
dhcpd dns 10.200.200.220 10.200.200.225 interface Wireless
dhcpd wins 10.200.200.220 10.200.200.225 interface Wireless
dhcpd lease 18000 interface Wireless
dhcpd domain company.com interface Wireless
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.5.41.40 source outside prefer
ssl trust-point vpn.company.com outside
webvpn
enable outside
anyconnect-essentials
svc image disk0:/anyconnect-win-2.5.0217-k9.pkg 1
svc image disk0:/anyconnect-macosx-i386-2.5.2017-k9.pkg 2
svc enable
tunnel-group-list enable
group-policy SSL_Client_Policy internal
group-policy SSL_Client_Policy attributes
wins-server value 10.200.200.220
dns-server value 10.200.200.220
vpn-tunnel-protocol IPSec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SSL_SPLIT
default-domain value company.com
webvpn
  sso-server none
  auto-signon allow uri * auth-type all
group-policy no-split-test internal
group-policy no-split-test attributes
banner value Welcome to company and Associates
ipsec-udp enable
split-tunnel-policy tunnelall
group-policy DfltGrpPolicy attributes
group-policy company internal
group-policy company attributes
ipsec-udp enable
username ciscoadmin password xxxxxxxxxxx encrypted privilege 15
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool SSL_VPN_POOL
authentication-server-group COMPANY-NT-AUTH
default-group-policy SSL_Client_Policy
tunnel-group DefaultWEBVPNGroup webvpn-attributes
group-alias company_SSL_VPN enable
tunnel-group company_group type remote-access
tunnel-group company_group general-attributes
authentication-server-group COMPANY-NT-AUTH LOCAL
default-group-policy company
tunnel-group company_group ipsec-attributes
pre-shared-key *****
tunnel-group x.x.x.53 type ipsec-l2l
tunnel-group x.x.x.53 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect tftp
  inspect esmtp
  inspect ftp
  inspect icmp
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect mgcp
  inspect h323 h225
  inspect h323 ras
  inspect sip
service-policy global_policy global
privilege cmd level 5 mode exec command ping
privilege cmd level 6 mode exec command write
privilege show level 5 mode exec command running-config
privilege show level 5 mode exec command version
privilege show level 5 mode exec command conn
privilege show level 5 mode exec command memory
privilege show level 5 mode exec command cpu
privilege show level 5 mode exec command xlate
privilege show level 5 mode exec command traffic
privilege show level 5 mode exec command interface
privilege show level 5 mode exec command clock
privilege show level 5 mode exec command ip
privilege show level 5 mode exec command failover
privilege show level 5 mode exec command arp
privilege show level 5 mode exec command route
privilege show level 5 mode exec command blocks
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:a0689b4c837c79a51e7a0cfed591dec9
: end
COMPANY-asa#
Parminder Sian
Hi Scott,
Please share the output of "sh cry isakmp sa" and sh crypto ipsec sa" after bringing up the tunnel. What we need to see is if tunnel shows up as "QM_idle" if yes, then are we encrypting packets from our side or not. Is there a natting or patting device on the way?
Also, according to your config PFS is enabled "crypto map OUTSIDE_MAP 5 set pfs", is it enabled on remote end as well.
Sian
Hi Sian,
Yes on their end the PFS is enabled for DH Group 2.
Here is the information that you requested:
company-asa# sh crypto isakmp sa
   Active SA: 3
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 3
1   IKE Peer: x.x.x.87
    Type    : user            Role    : responder
    Rekey   : no              State   : AM_ACTIVE
2   IKE Peer: x.x.x.53
    Type    : L2L             Role    : initiator
    Rekey   : no              State   : MM_ACTIVE
3   IKE Peer: x.x.x.25
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG4
company-asa# sh crypto ipsec sa
interface: outside
    Crypto map tag: OUTSIDE_MAP, seq num: 5, local addr: x.x.x.13
      local ident (addr/mask/prot/port): (10.200.0.0/255.255.0.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.9.0/255.255.255.0/0/0)
      current_peer: x.x.x.53
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 10744, #pkts decrypt: 10744, #pkts verify: 10744
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: x.x.x.13, remote crypto endpt.: x.x.x.53
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 500EC8BF
      current inbound spi : 8DAE3436
    inbound esp sas:
      spi: 0x8DAE3436 (2377004086)
         transform: esp-3des esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, PFS Group 2, }
         slot: 0, conn_id: 32768, crypto-map: OUTSIDE_MAP
         sa timing: remaining key lifetime (kB/sec): (3914946/24388)
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0x500EC8BF (1343146175)
         sa timing: remaining key lifetime (kB/sec): (3915000/24388)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
    Crypto map tag: outside_dyn_map, seq num: 20, local addr: x.x.x.13
      local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
      remote ident (addr/mask/prot/port): (172.20.20.8/255.255.255.255/0/0)
      current_peer: x.x.x.87, username: ewebb
      dynamic allocated peer ip: 172.20.20.8
      #pkts encaps: 16434, #pkts encrypt: 16464, #pkts digest: 16464
      #pkts decaps: 19889, #pkts decrypt: 19889, #pkts verify: 19889
      #pkts not compressed: 16434, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 30, #pre-frag failures: 0, #fragments created: 60
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 60
      local crypto endpt.: x.x.x.13/4500, remote crypto endpt.: x.x.x.87/2252
      path mtu 1500, ipsec overhead 66, media mtu 1500
      current outbound spi: 2D712C9F
      current inbound spi : 0EDB79C8
    inbound esp sas:
      spi: 0x0EDB79C8 (249264584)
         in use settings ={RA, Tunnel,  NAT-T-Encaps, }
         slot: 0, conn_id: 65536, crypto-map: outside_dyn_map
         sa timing: remaining key lifetime (sec): 18262
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x2D712C9F (762391711)
         sa timing: remaining key lifetime (sec): 18261
         IV size: 8 bytes
         Anti replay bitmap:
