SHA1 Deprecation and Anyconnect using ASA's
david webb
Greetings to All,
We are running client a VPN using Anyconnect and ASA 5510's and 5520's using IKEv2. We have been told that as of 2/14/2017, Microsoft will no longer support signed certificates with SHA1. Here's what I've done to fix this so far:
1. I've updated our VPN server (the ASAs) Identity Certificates, but am concerned that it may also need to be implemented in the IKEv2 policy and IPSEC proposal.
2. I was able to get the IKEV2 Policy to use SHA256
3. I was NOT able to get the IPSEC proposal to support SHA2. I've seen a thread that points to our hardware platform as not supporting this.
The major concern is this: on 2/14/2017 will our Anyconnect clients still be able work? I would think so, but I'm trying to get a definitive answer.
Any help would be greatly appreciated.
Thanks!
Dave
Rahul Govindan
The Microsoft update only mentions SHA-1 TLS certificates. This should not affect IKE and IPsec proposals. As long as your certificate is updated to SHA2, you should have no issues.
6 Replies 6
Rahul Govindan
Thanks, Rahul. That's what I suspected. I just need to be 100% sure. --DW
kevin.fogarty
I'm not sure if this answer is 100% correct. According to Cisco it depends on the version of Anyconnect you are using. See attached.
I think that might be from an older release note. MS documentation states that Code signing certificates should be unaffected, only TLS certs will be made invalid.
https://social.technet.microsoft.com/wiki/contents/articles/32288.windows-enforcement-of-sha1-certificates.aspx#Summary
But in any case, sticking to the Anyconnect 4.3 and 4.4 releases are recommended as they should have the latest code signing certs.
I have to admit there is a lot of conflicting/contradicting info out there regarding this issue. I think I misunderstood the original post. I am concerned that Win 7 will not launch the Anyconnect client on the PC if it was signed with a SHA1 cert and that's what I'm trying to find out. Sorry if I caused confusion.
No worries :) Your post made me re-check the MS documentation again - which is always good. You are right that there have been changes about the SHA-1 deprecation plan from earlier info provided. Hopefully, the MS link posted about should be single source of truth for the changes that will come about later this month.
