Side2Side not working
MPIBGC_Jena
Community Member
we are trying to set up a side2side connection between 2 locations
over the internet.
We already have succesfully connected both ASAs, but we are not able
to comunicate through the tunnel.
10.64.0.0  IN-ASA-Remote-OUT-------INTERNET------OUT-ASA-Main
        (is DMZ, only interface)
A ping on the remote side starts the tunnel, but the ping is lost - no reply.
When we try to traceroute from the Main-ASA to the remote ASA not the tunnel is
used, but the main gateway.
The Main-ASA has only one interface, because we do not use it for routing.
On the main side we have private and offical ip ranges, which should be transported
through the tunnel. On the remote side, we only have a private segment, which should
have direct access to our networks.
Normal VPN (ipsec and ssl) is running fine.
How can we check the routing ?
Which parts of the configuration would be helpful ?
Bye, Peer
Collin Clark
Take a look at this document, it's very helpful when troubleshooting VPN's.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
ju_mobile
Level 5
Level 5
As I understand it were going to have an interesting chat. You asked how you can verify connectivity and routing.
I would recommend that you use ping to verify that the two firewalls can communicate with each other.
The configuration of a single interface is not one that I've personally tried and I'm assuming that you would need to enable access between hosts on the same interface. The acl's would need to be defined for the same interface and your NAT translations if required would need to define the same interface.
If your gateways are different for Internet and your internal traffic then you will need to ensure that a static is in place for the peer or via the default and for the subnet your attempting to get to.
I'd have to suggest that you post your configurations. Do you really need the single interface, for simplicity would it not be easier to add an inside and the your routing for you remote subnet is sent to the inside.
Best Regards
Ju
http://helpamunky.wordpress.com/
