Site to Site Phase 2 issue - Unknown identification type, Phase 2, Type 7
FAmore555
Hi Everyone!
I'm trying to get a tunnel up between a 5520 ASA & a Cisco RV325 WAN VPN Router and having issues getting this tunnel up, i hope someone can shed some light on what this message means? Any help is appreciated thanks!
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 104
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing SA payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, Oakley proposal is acceptable
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing VID payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, Received DPD VID
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing IKE SA payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, IKE SA Proposal # 1, Transform # 0 acceptable Matches global IKE entry # 18
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing ISAKMP SA payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing Fragmentation VID + extended capabilities payload
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + NONE (0) total length : 180
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing ke payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing ISA_KE payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, processing nonce payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing ke payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing nonce payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing Cisco Unity VID payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing xauth V6 VID payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, Send IOS VID
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, constructing VID payload
Aug 28 16:16:24 [IKEv1 DEBUG]IP = X.X.X.X, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, Connection landed on tunnel_group X.X.X.X
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, Generating keys for Responder...
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 256
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + NONE (0) total length : 64
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, processing ID payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, processing hash payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, Computing hash for ISAKMP
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing ID payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing hash payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing dpd vid payload
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + VENDOR (13) + NONE (0) total length : 84
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, PHASE 1 COMPLETED
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, Keep-alive type for this connection: DPD
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, Starting P1 rekey timer: 15648 seconds.
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Add to IKEv1 Tunnel Table succeeded for SA with logical ID 42242048
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Add to IKEv1 MIB Table succeeded for SA with logical ID 42242048
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE RECEIVED Message (msgid=f743418a) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NONE (0) total length : 156
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, processing SA payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, processing nonce payload
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Received remote IP Proxy Subnet data in ID Payload: Address X.X.X.X, Mask 255.255.255.0, Protocol 0, Port 0
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Unknown identification type, Phase 2, Type 7
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Error processing payload: Payload ID: 5
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, QM FSM error (P2 struct &0x76cb2118, mess id 0xf743418a)!
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, IKE QM Responder FSM error history (struct &0x76cb2118) <state>, <event>: QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH-->QM_BLD_MSG2, EV_VALIDATE_MSG-->QM_BLD_MSG2, EV_DECRYPT_OK-->QM_BLD_MSG2, NullEvent
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, sending delete/delete with reason message
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Removing peer from correlator table failed, no match!
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, IKE SA MM:caee9596 rcv'd Terminate: state MM_ACTIVE flags 0x00000042, refcnt 1, tuncnt 0
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Remove from IKEv1 Tunnel Table succeeded for SA with logicalId 42242048
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Remove from IKEv1 MIB Table succeeded for SA with logical ID 42242048
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, IKE SA MM:caee9596 terminating: flags 0x01000002, refcnt 0, tuncnt 0
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing blank hash payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing IKE delete payload
Aug 28 16:16:24 [IKEv1 DEBUG]Group = X.X.X.X, IP = X.X.X.X, constructing qm hash payload
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=89bca91a) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Warning: Ignoring IKE SA (src) without VM bit set
Aug 28 16:16:24 [IKEv1]Group = X.X.X.X, IP = X.X.X.X, Session is being torn down. Reason: Unknown
Aug 28 16:16:24 [IKEv1]IP = X.X.X.X, Received encrypted packet with no matching SA, dropping
Aug 28 16:16:34 [IKEv1]IP = X.X.X.X, Received encrypted packet with no matching SA, dropping
Aug 28 16:16:54 [IKEv1]IP = X.X.X.X, Received encrypted packet with no matching SA, dropping
Aug 28 16:17:34 [IKEv1]IP = X.X.X.X, Received encrypted packet with no matching SA, dropping
Check the interesting traffic ACL on both ends and confirm they match, check to see if you have identical settings in the transform set and confirm that you have a NAT exemption rule configured.
