Site-to-site VPN Problem
santiago.jem
Hi guys,
Been troubleshooting on an IPSec tunnel that went down without warning:
As described in the forum thread, https://supportforums.cisco.com/thread/2091809
the policies look identical on both sides.
I've checked on the IKEv1 policy on both asa's and here's the output:
asa_branch:
asa_branch# sh run crypto ma
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set pfs
crypto map outside_map0 1 set peer x.x.x.x
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
asa_hq:
asa_hq# sh run crypto ma
crypto map Outside_map0 1 match address Outside_cryptomap
crypto map Outside_map0 1 set pfs
crypto map Outside_map0 1 set peer y.y.y.y
crypto map Outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map0 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
They are identical. But still no VPN tunnel is up:
asa_branch# sh crypto isakmp sa
There are no IKEv1 SAs
There are no IKEv2 SAs
asa#
May I know what other troubleshooting steps that I need to do?
Thank you.
8 Replies 8
shine pothen
Level 3
Level 3
can you get the config of both the location
in the above config tunnel-group is missing and pre-shared key.
is the cry and iskamp set to the outside interface.
Hello Shine,
Thanks for the reply. I'm really wondering, what could have I done wrong?
No vpn tunnel is forming not even MM_MSG are there.
Here is the config:
asa_branch:
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto map outside_map0 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map0 2 match address outside_cryptomap_1
crypto map outside_map0 2 set pfs
crypto map outside_map0 2 set peer a.a.a.a
crypto map outside_map0 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 2 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map0 interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 enable inside
crypto ikev1 policy 120
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
dhcpd address 10.1.1.10-10.1.1.30 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1
group-policy GroupPolicy_x.x.x.x internal
group-policy GroupPolicy_x.x.x.x attributes
vpn-tunnel-protocol ikev1 ikev2
group-policy GroupPolicy_a.a.a.a internal
group-policy GroupPolicy_a.a.a.a attributes
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x general-attributes
default-group-policy GroupPolicy_x.x.x.x
tunnel-group x.x.x.x ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
tunnel-group a.a.a.a type ipsec-l2l
tunnel-group a.a.a.a general-attributes
default-group-policy GroupPolicy_a.a.a.a
tunnel-group a.a.a.a ipsec-attributes
class-map inspection_default
match default-inspection-traffic
I have very limited access to to asa_hq here are some of it:
crypto dynamic-map Outside_dyn_map 20 set ikev1 transform-set ESP-AES-128-SHA ESP-3DES-MD5
crypto dynamic-map Outside_dyn_map 40 set ikev1 transform-set ESP-3DES-SHA
crypto dynamic-map Outside_dyn_map 60 set ikev1 transform-set ESP-3DES-SHA
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map0 2 match address Outside_cryptomap_1
crypto map Outside_map0 2 set pfs
crypto map Outside_map0 2 set peer a.a.a.a
crypto map Outside_map0 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map0 2 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map Outside_map0 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map0 interface Outside
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable Outside
crypto ikev1 enable Outside
crypto ikev1 policy 40
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption des
hash sha
group 1
lifetime 86400
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y general-attributes
default-group-policy GroupPolicy_y.y.y.y
tunnel-group y.y.y.y ipsec-attributes
nkarthikeyan
Level 7
Level 7
Hi Jemel,
Is it a new setup or which was working earlier??????
Just post the complete VPN configuration with phase 1 and phase 2 parameters, crypto acl's.....
If everything is configured then have you tried establishing the intresting traffic....
You can verify with the helpful command which is builtin help command.
asa-pri(config)# vpnsetup site-to-site steps and check whether you have all the parameters set as per the help command...
however that help command shows Site to Site setup samples which prior to 8.3. If you ASA version is 8.3 and above then you may need to make some changes in command syntax like the below
crypto ipsec ikev1 transform-set myset esp-3des esp-md5-hmac
crypto map rlc 10 match address s2svpn
crypto map rlc 10 set peer 10.144.139.213
crypto map rlc 10 set ikev1 transform-set myset
crypto map rlc interface outside
crypto map abc 100 match address s2svpn
crypto ikev1 policy 10
encryption 3des
hash md5
group 2
lifetime 86400
tunnel-group SF type ipsec-l2l
tunnel-group 10.144.139.213 type ipsec-l2l
tunnel-group 10.144.139.213 ipsec-attributes
Please do rate if the given information helps.
By
Karthik
Hello Karthik,
This was a working config.
All of sudden VPN Tunnel can't be established with me doing nothing.
I've posted the vpn parameters above.
Corret me if I'm wrong, on the first match of the IKEv1 transform set between peers and IKEv1 policy and VPN Tunnel should be established right?
Do you any ways to possibly find the culprit of this issue?
After a series of debugs and reading other websites, this issue pointed out on pre-shared key mismatch.
Thanks to http://www.petenetlive.com/KB/Article/0000216.htm
I just keyed-in the pre-shared key again and the VPN Tunnel is up and running.
Hello Jemel,
good to hear that VPN is up and running. but if it was just the pre-shared key mismatch.. which u have re-entered. then before itself you should have got error message like Msg_Wait 5 or Msg_Wait_6 which says it is pre-shared key mistach u know.
Shine
Hi Shine,
The reason that there was no error messages like Msg_Wait 5 or Msg_Wait_6 was that because there was no traffic initiated. I tried pinging the server on the other side. While pinging, "show crypto isakmp sa" showed the
Msg_Wait_6. Right there, I had concluded that it was the pre-shared key.
Thanks for the information Shine!
Jeme
Good good ...:)
Shine
