site to site vpn problem
zachlin19381
I want to do site to site vpn with firepower and sophos XG firewall
when i config firepower have a PRF to setup but Sophos don't have PRF to setup
i wonder is it  cause me setup not working
5 Replies 5
Hi @zachlin19381
PRF is used in IKEv2. Are you selecting IKEv2 on Sophos or does Sophos not support IKEv2? If it does not support IKEv2 then you'd have to use IKEv1 which Firepower also supports.
I use iKEv2 to setup Sophos but I can not see the PRF option
This is probably a question for Sophos rather than the Cisco forum. It may well be that PRF on the sophos is the same as integrity value, in your instance SHA-256. You could use IKEv1 if you don't get anywhere with Sophos, as IKEv1 doesn't use PRF.
FYI, don't use DH group 2 - it's weak and depreciated in the latest versions of software.
PRF if not support by each side or you not pretty sure it support then it better to disable it.
because if make traffic one direction and unknown behavior
I’ll ask sophos to this question
How to disable PRF on Cisco ?
it won’t let me blank...
