SR520 DMVPN functionality problem
Hello people,
I have a serious problem with cisco SR 520 router and functionality that is wrote on the paper!
On cisco site I found that SR 520 support DMVPN, I ordered the router and it came with IOS:
(SR520-ADVIPSERVICESK9-M), Version 12.4(20)T6. Later I found that it does not support
NHRP protocol which is a base for DMVPN functionality and spoke-to-spoke VPN tunnels.
I suppose that the problem is in IOS version that is shiped with router.
Please, if you know, tell me were is the problem and wich IOS version should I choose ?
Should I take the latest ( 12.4.24T6) or some special release ?
Thanks in advance,
Vladimir
Herbert Baerten
Hi Vladimir
DMVPN support on SR520 was indeed only added in 12.4(24)T so I would suggest to go for the latest, i.e. 12.4(24)T6.
hth
Herbert
Herbert Baerten
Hi Vladimir
hth
Herbert
Thanks Herbert,
I already did what you just said and it works !
Nevertheless, thank you very much for your reply!
Vladimir
