SSL VPN Group-Lock problem
mbsshoards
I am trying to lock groups to a specific tunnel group but unfortunitly no matter what I do the group-lock feature doesnt seem to work. Basically here is what I want to do:
1-Users detail is pulled from AD through LDAP
2-AD group is mapped to the appropriate group on the ASA using attribute mapping
3-user should only use the tunnel that he/she is locked to
4-this all should be done without the user needing to select a group the vpn portal
5-we will be using Any connect and VPN portal for communication
All works fine except the group-lock feature. If enabled and set to "group-lock value NET_ADMIN_G" I get the following error on debug webvpn and the user is not allowed in.
webvpn_auth.c:http_webvpn_post_authentication[1503]
WebVPN: user: (test) authenticated.
webvpn_auth.c:http_webvpn_auth_accept[2905]
User came in on group he wasn't supposed to come in on!
when removed no matter what I do the user is mapped to DefaultWEBVPNGroup tunnel group,
SSLVPN(config-group-policy)# sho vpn-sessiondb webvpn
Session Type: WebVPN
Username     : test      Index        : 132
Public IP    : 10.1.1.1
Protocol     : Clientless
License      : AnyConnect Premium
Encryption   : Clientless: (1)AES256  Hashing      : Clientless: (1)SHA1
Bytes Tx     : 252897                 Bytes Rx     : 48894
Group Policy : NET_ADMIN              Tunnel Group : DefaultWEBVPNGroup
Login Time   : 11:18:13 EDT Fri Mar 22 2013
Duration     : 0h:01m:12s
Inactivity   : 0h:00m:00s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
Asa is on 9.11.4.
group policy:
group-policy NET_ADMIN internal
group-policy NET_ADMIN attributes
wins-server none
dns-server value 2.2.2.2
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-session-timeout alert-interval 25
vpn-filter value VPN_SPLIT_TUNNEL
vpn-tunnel-protocol ikev1 ssl-client ssl-clientless
password-storage disable
ip-comp enable
re-xauth disable
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN_SPLIT_TUNNEL
default-domain value brightstarcorp.com
split-dns value brightstarcorp.com
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout none
ip-phone-bypass disable
client-bypass-protocol disable
gateway-fqdn value svgmelb.au.brightstarcorp.com
leap-bypass disable
nem disable
backup-servers clear-client-config
msie-proxy method no-modify
vlan none
nac-settings none
address-pools value SSL_POOL
ipv6-address-pools none
scep-forwarding-url none
client-firewall none
client-access-rule none
webvpn
  url-list value NETADMIN_BOOKMARK
  filter value INTERNAL_WEBACL
  homepage use-smart-tunnel
  anyconnect ssl dtls enable
  anyconnect mtu 1406
  anyconnect keep-installer installed
  anyconnect ssl keepalive 20
  anyconnect ssl rekey time none
  anyconnect ssl rekey method none
  anyconnect dpd-interval client 30
  anyconnect dpd-interval gateway 30
  anyconnect ssl compression lzs
  anyconnect dtls compression lzs
  anyconnect modules value posture
  anyconnect profiles value net_admin_p type user
  anyconnect ask none default webvpn
  customization value NETADMIN_PORTAL
  hidden-shares visible
  activex-relay enable
  file-entry enable
  file-browsing enable
  url-entry enable
  deny-message value Login was successful, but because certain criteria have not been met, you do not have permission to use any of the VPN features. Contact your IT administrator for more information.
  anyconnect ssl df-bit-ignore disable
  always-on-vpn profile-setting
  auto-signon allow uri * auth-type all
Tunnel Group:
tunnel-group NET_ADMIN_G type remote-access
tunnel-group NET_ADMIN_G general-attributes
address-pool SSL_POOL
authentication-server-group LDAP
authorization-server-group LDAP
accounting-server-group RGROUPADMIN
default-group-policy NET_ADMIN
authorization-required
tunnel-group NET_ADMIN_G webvpn-attributes
customization NETADMIN_PORTAL
group-alias infra_network enable
group-url https://x.x.x.x/network enable
dns-group DNSGROUP
Any ideas?
Thanks in advance
6 Replies 6
Please include "debug ldap 255" and "debug aaa common 255".
Thanks.
Portu.
Hi Portu,
Heres debug Ldap:
SLVPN#
[553] Session Start
[553] New request Session, context 0x00007fff33beb228, reqType = Authentication
[553] Fiber started
[553] Creating LDAP context with uri=ldap://1.1.1.13:389
[553] Connect to LDAP server: ldap://1.1.1.13:389, status = Successful
[553] supportedLDAPVersion: value = 3
[553] supportedLDAPVersion: value = 2
[553] Binding as bind
[553] Performing Simple authentication for test to 1.1.1.13
[553] LDAP Search:
Base DN = [OU=xx ENTERPRISE,DC=xxx,DC=com]
Filter  = [sAMAccountName=test]
Scope   = [SUBTREE]
[553] User DN = [CN=test,OU=Users,OU=xx,OU=Australia,OU=APAC,OU=ENTERPRISE,DC=xxx,DC=com]
[553] Talking to Active Directory server 1.1.1.13
[553] Reading password policy for test, dn:CN=test,OU=Users,OU=xxx,OU=Australia,OU=APAC,OU=ENTERPRISE,DC=xxx,DC=com
[553] Read bad password count 0
[553] Binding as test
[553] Processing LDAP response for user test
[553] Message (test):
[553] Authentication successful for test to 1.1.1.13
[553] Retrieved User Attributes:
[553] objectClass: value = top
[553] objectClass: value = person
[553] objectClass: value = organizationalPerson
[553] objectClass: value = user
[553] cn: value = test
[553] sn: value =
[553] c: value = AU
[553] l: value = xxx
[553] st: value = xxx
[553] title: value = test user  / IT
[553] description: value = Network
[553] postalCode: value = xxx
[553] physicalDeliveryOfficeName: value = xxx
[553] telephoneNumber: value = xxx
[553] givenName: value = test
[553] distinguishedName: value = CN=test,OU=Users,OU=xxx,OU=Australia,OU=APAC,OU=BS ENTERPRISE,DC=br
[553] instanceType: value = 4
[553] whenCreated: value = 20110327224420.0Z
[553] whenChanged: value = 20130319223953.0Z
[553] displayName: value = test
[553] uSNCreated: value = 84454809
[553] memberOf: value = CN=APAC.Cisco.Tel.Users,OU=Security Groups,OU=xxx,OU=Australia,OU=APAC,OU=
[553] mapped to IETF-Radius-Class: value = CN=APAC.Cisco.Tel.Users,OU=Security Groups,OU=xxx,OU=Australia,OU=APAC,OU=BS ENTERPRISE,DC=xxx,DC=com
[553] mapped to LDAP-Class: value = CN=APAC.Cisco.Tel.Users,OU=Security Groups,OU=xxx,OU=Australia,OU=APAC,OU=BS ENTERPRISE,DC=xxx,DC=com
[553] memberOf: value = CN=Networks,OU=Distribution Groups,OU=xxx,OU=Australia,OU=APAC,OU=
[553] mapped to IETF-Radius-Class: value = NET_ADMIN
[553] mapped to LDAP-Class: value = NET_ADMIN
[553] memberOf: value = CN=Email Notify SG10,OU=Distribution Groups,OU=Corporate
[553] mapped to IETF-Radius-Class: value = CN=Email Notify SG10,OU=Distribution Groups,OU=Corporate,OU=US & Canada,OU=BS ENTERPRISE,DC=xxx,DC=com
[553] mapped to LDAP-Class: value = CN=Email Notify SG10,OU=Distribution Groups,OU=Corporate,OU=US & Canada,OU=BS ENTERPRISE,DC=xxx,DC=com
aaa common debug:
AAA API: In aaa_open
AAA session opened: handle = 3
AAA API: In aaa_process_async
aaa_process_async: sending AAA_MSG_PROCESS
AAA task: aaa_process_msg(0x00007fff28d327d0) received message type 0
AAA FSM: In AAA_StartAAATransaction
AAA FSM: In AAA_InitTransaction
Initiating authentication to primary server (Svr Grp: LDAP)
AAA FSM: In AAA_BindServer
AAA_BindServer: Using server: 1.1.1.13
AAA FSM: In AAA_SendMsg
User: test
Resp:
callback_aaa_task: status = 1, msg =
AAA FSM: In aaa_backend_callback
aaa_backend_callback: Handle = 3, pAcb = 0x00007fff3401b550
AAA task: aaa_process_msg(0x00007fff28d327d0) received message type 1
AAA FSM: In AAA_ProcSvrResp
Back End response:
Authentication Status: 1 (ACCEPT)
AAA FSM: In AAA_NextFunction
AAA_NextFunction: i_fsm_state = IFSM_PRIM_AUTHENTICATE, auth_status = ACCEPT
AAA_NextFunction: authen svr = BSTAR_LDAP, author svr = LDAP, user pol = NET_ADMIN, tunn pol = DfltGrpPolicy
AAA_NextFunction: New i_fsm_state = IFSM_USER_GRP_POLICY,
aaai_policy_name_to_server_id(NET_ADMIN)
Got server ID 0 for group policy DB
Initiating user group policy lookup (Svr Grp: GROUP_POLICY_DB)
User: NET_ADMIN
Resp:
grp_policy_ioctl(0x00000000047eb0e0, 114698, 0x00007fff28d31c90)
grp_policy_ioctl: Looking up NET_ADMIN
Back End response:
User Group Policy Status: 1 (ACCEPT)
AAA_NextFunction: i_fsm_state = IFSM_USER_GRP_POLICY, auth_status = ACCEPT
AAA_NextFunction: New i_fsm_state = IFSM_AUTHORIZE,
Initiating authorization query (Svr Grp: LDAP)
User: test
Resp:
Back End response:
Authorization Status: 1 (ACCEPT)
AAA_NextFunction: i_fsm_state = IFSM_AUTHORIZE, auth_status = ACCEPT
AAA_NextFunction: author svr = BSTAR_LDAP, user pol = NET_ADMIN, tunn pol = DfltGrpPolicy
AAA_NextFunction: New i_fsm_state = IFSM_AUTH_GRP_POLICY,
Initiating authorization group policy lookup (Svr Grp: GROUP_POLICY_DB)
User: NET_ADMIN
Resp:
Back End response:
Authorization Group Policy Status: 1 (ACCEPT)
AAA_NextFunction: i_fsm_state = IFSM_AUTH_GRP_POLICY, auth_status = ACCEPT
AAA_NextFunction: New i_fsm_state = IFSM_TUNN_GRP_POLICY,
aaai_policy_name_to_server_id(DfltGrpPolicy)
Initiating tunnel group policy lookup (Svr Grp: GROUP_POLICY_DB)
User: DfltGrpPolicy
Resp:
grp_policy_ioctl: Looking up DfltGrpPolicy
Back End response:
Tunnel Group Policy Status: 1 (ACCEPT)
AAA_NextFunction: i_fsm_state = IFSM_TUNN_GRP_POLICY, auth_status = ACCEPT
Class attribute created from LDAP-Class attribute
AAA_NextFunction: New i_fsm_state = IFSM_DONE,
AAA FSM: In AAA_ProcessFinal
Checking simultaneous login restriction (max allowance=3) for user test
AAA FSM: In AAA_Callback
user attributes:
  1     User-Name(1)      6    "test"
  2     User-Password(2)     10    (hidden)
  3     Group-Policy(4121)      9    "NET_ADMIN"
  4     AAA-AVP-Table(4243)    11268    "[04],[00][00]t[00][00][00][F8][03][00][00][0F][04][00]"
  5     LDAP-Class(20520)     10    "NET_ADMIN[00]"
  6     LDAP-Class(20520)     11    "USERS[00]"
user policy attributes:
  1     Filter-Id(11)      8    "VPN_SPLIT_TUNNEL"
  2     Session-Timeout(27)      4    0
  3     Idle-Timeout(28)      4    30
  4     Access-Hours(4097)      0    0x00007fff35d685e0   ** Unresolved Attribute **
  5     Simultaneous-Logins(4098)      4    3
  6     Primary-DNS(4101)      4    IP: 1.1.1.13
  7     Secondary-DNS(4102)      4    IP: 1.1.1.30
  8     Primary-WINS(4103)      4    IP: 0.0.0.0
  9     Secondary-WINS(4104)      4    IP: 0.0.0.0
10     Tunnelling-Protocol(4107)      4    52
11     Banner(4111)    446    "This is a PRIVATE computer system, which may be acces"
12     Store-PW(4112)      4    0
13     Split-Tunnel-Inclusion-List(4123)      8    "VPN_SPLIT_TUNNEL"
14     Default-Domain-Name(4124)     18    "xxxxcorp.com"
15     Secondary-Domain-Name-List(4125)     18    "xxxxcorp.com"
16     Nat-Enabled-IPSec(4130)      4    0
17     IPSec-UDP-Port(4131)      4    10000
18     IPComp(4135)      4    1
19     Authentication-On-Rekey(4138)      4    0
20     Required-Firewall-Vendor-Code(4141)      0    0x0000000002e006b0   ** Unresolved Attribute **
21     Required-Firewall-Product-Code(4142)      0    0x0000000002e006b0   ** Unresolved Attribute **
22     Required-Firewall-Description(4143)      0    0x00007fff35d687fa   ** Unresolved Attribute **
23     Secure-unit-config(4144)      4    0
24     Individual-user-auth-config(4145)      4    0
25     User-auth-idle-timeout(4146)      4    0
26     Cisco-IP-telephony-config(4147)      4    0
27     Split-Tunneling-Policy(4151)      4    1
28     Required-Firewall-Capability(4152)      0    0x0000000002e006b0   ** Unresolved Attribute **
29     Client Firewall Optional(4154)      0    0x0000000002e006b0   ** Unresolved Attribute **
30     Backup-Ip-Sec-Peers-Enabled(4155)      4    2
31     Network-Extension-Mode-Allowed(4160)      4    0
32     URL list name(4167)     17    "NETADMIN_BOOKMARK"
33     ACL-like filters(4169)      8    "INTERNAL_WEBACL"
34     Cisco-LEAP-Passthrough-config(4171)      4    0
35     IKE Client Type and Version Limiting policy rules(4173)      0    0x00007fff35d68835   ** Unresolved Attribute **
36     IE-Proxy-Server-Method(4177)      4    1
37     The tunnel group that tunnel must be associated with(4181)     11    "NET_ADMIN_G"
38     User ACL for inbound traffic(4182)      8    ""
39     User ACL for outbound traffic(4183)      8    ""
40     Indicates whether or not PFS is required for IPSec(4184)      4    0
41     WebVPN URL Entry enable(4189)      4    1
42     WebVPN File Server Entry enable(4191)      4    1
43     WebVPN File Server Browsing enable(4192)      4    1
44     WebVPN SVC Keep enable(4201)      4    1
45     WebVPN SVC Keepalive interval(4203)      4    20
46     WebVPN SVC Client DPD period(4204)      4    30
47     WebVPN SVC Gateway DPD period(4205)      4    30
48     WebVPN SVC Rekey period(4206)      4    0
49     WebVPN SVC Rekey method(4207)      4    0
50     WebVPN SVC Compression(4208)      4    2
51     WebVPN Customization(4209)     15    "NETADMIN_PORTAL"
52     WebVPN Deny message(4212)    180    "Login was successful, but because certain criteria ha"
53     WebVPN SVC DTLS Compression(4213)      4    2
54     Extended Authentication-On-Rekey(4218)      4    0
55     WebVPN SVC DTLS enable(4219)      4    1
56     WebVPN SVC MTU(4221)      4    1406
57     CIFS hidden shares(4222)      4    1
58     CVC-Modules(4223)      7    "posture"
59     CVC-Profile(4224)     17    "net_admin_p#user,"
60     CVC-Ask(4227)      4    4
61     CVC-Ask-Timeout(4228)      4    0
62     WebVPN ActiveX Relay(4233)      4    1
63     VLAN ID(4236)      4    0
64     NAC Settings(4237)      0    0x00007fff35d68985   ** Unresolved Attribute **
65     WebVPN Session timeout alert interval(4245)      4    25
66     List of address pools to assign addresses from(4313)     13    "SSL_POOL"
67     List of IPv6 address pools to assign addresses from(4314)      0    0x00007fff35d68998   ** Unresolved Attribute **
68     Smart tunnel on home page enable(4324)      4    1
69     Disable Always-On VPN(4325)      4    0
70     SVC ignore DF bit(4326)      4    0
71     Client Bypass Protocol(4331)      4    0
72     Gateway FQDN(4333)     29    "xxx.xxxxcorp.com"
73     CA URL for SCEP enrollment(20530)      0    0x00007fff35d689c7   ** Unresolved Attribute **
tunnel policy attributes:
  4     Access-Hours(4097)      0    0x00007fff351cddd0   ** Unresolved Attribute **
  5     Simultaneous-Logins(4098)      4    0
  6     Primary-DNS(4101)      4    IP: 10.125.3.7
  7     Secondary-DNS(4102)      4    IP: 10.125.3.5
10     Tunnelling-Protocol(4107)      4    124
13     Group-Policy(4121)     13    "DfltGrpPolicy"
14     Split-Tunnel-Inclusion-List(4123)      8    "VPN_SPLIT_TUNNEL"
15     Default-Domain-Name(4124)     18    "xxxxcorp.com"
16     Secondary-Domain-Name-List(4125)      0    0x00007fff351cdfc7   ** Unresolved Attribute **
17     Nat-Enabled-IPSec(4130)      4    0
18     IPSec-UDP-Port(4131)      4    10000
19     IPComp(4135)      4    0
20     Authentication-On-Rekey(4138)      4    0
21     Secure-unit-config(4144)      4    0
22     Individual-user-auth-config(4145)      4    0
23     User-auth-idle-timeout(4146)      4    30
24     Cisco-IP-telephony-config(4147)      4    0
25     Split-Tunneling-Policy(4151)      4    1
26     Client Firewall Optional(4154)      0    0x00007fff351cdfec   ** Unresolved Attribute **
27     Backup-Ip-Sec-Peers-Enabled(4155)      4    1
28     Group-giaddr(4157)      4    IP: 0.0.0.0
29     Intercept-DHCP-Configure-Msg(4158)      4    0
30     Client-Subnet-Mask(4159)      4    IP: 255.255.255.255
32     WebVPN Content Filter Parameters(4165)      4    0
33     WebVPN Parameters configuration(4166)      4    1
34     URL list name(4167)      0    0x00007fff351ce008   ** Unresolved Attribute **
35     Forwarded ports(4168)      0    0x00007fff351ce009   ** Unresolved Attribute **
36     ACL-like filters(4169)      8    "INTERNAL_WEBACL"
37     Cisco-LEAP-Passthrough-config(4171)      4    0
38     Default WebVPN homepage(4172)      0    0x00007fff351ce016   ** Unresolved Attribute **
39     IKE Client Type and Version Limiting policy rules(4173)      0    0x00007fff351ce017   ** Unresolved Attribute **
40     Application Access Name(4175)     18    "Application Access"
41     IE-Proxy-Server(4176)      0    0x00007fff351ce02b   ** Unresolved Attribute **
42     IE-Proxy-Server-Method(4177)      4    1
43     IE-Proxy-Server-Exceptions(4178)      0    0x00007fff351ce030   ** Unresolved Attribute **
44     IE-Proxy-Server-Bypass-Local(4179)      4    0
45     The tunnel group that tunnel must be associated with(4181)      0    0x00007fff351ce035   ** Unresolved Attribute **
46     Indicates whether or not PFS is required for IPSec(4184)      4    0
47     NAC Enable/Disable(4185)      4    0
48     NAC Status Query Timer(4186)      4    300
49     NAC Revalidation Timer(4187)      4    36000
50     NAC Default ACL(4188)      8    ""
51     WebVPN URL Entry enable(4189)      4    0
52     WebVPN File Server Entry enable(4191)      4    0
53     WebVPN File Server Browsing enable(4192)      4    0
54     WebVPN Port Forwarding enable(4193)      4    0
55     WebVPN Port Forwarding Exchange Proxy enable(4194)      4    0
56     WebVPN Port Forwarding HTTP Proxy enable(4195)      4    0
57     WebVPN SVC enable(4199)      4    0
58     WebVPN SVC Required enable(4200)      4    0
59     WebVPN SVC Keep enable(4201)      4    0
60     WebVPN SVC Keepalive interval(4203)      4    20
61     WebVPN SVC Client DPD period(4204)      4    30
62     WebVPN SVC Gateway DPD period(4205)      4    30
63     WebVPN SVC Rekey period(4206)      4    0
64     WebVPN SVC Rekey method(4207)      4    0
65     WebVPN SVC Compression(4208)      4    2
66     WebVPN Customization(4209)      0    0x00007fff351ce08a   ** Unresolved Attribute **
67     Single Sign On Server Name(4210)      0    0x00007fff351ce08b   ** Unresolved Attribute **
68     WebVPN SVC Firewall Rule(4211)     17    "private#,public#,"
69     WebVPN Deny message(4212)    180    "Login was successful, but because certain criteria ha"
70     WebVPN SVC DTLS Compression(4213)      4    2
71     HTTP compression method(4216)      4    0
72     Maximum object size to ignore for updating the session timer(4217)      4    4
73     Extended Authentication-On-Rekey(4218)      4    0
74     WebVPN SVC DTLS enable(4219)      4    1
75     WebVPN SVC MTU(4221)      4    1406
76     CIFS hidden shares(4222)      4    0
77     CVC-Modules(4223)     20    "dart,vpngina,posture"
78     CVC-Profile(4224)     15    "IPSEC_VPN#user,"
79     CVC-IKE-Retry-Timeout(4225)      4    10
80     CVC-IKE-Retry-Count(4226)      4    3
81     CVC-Ask(4227)      4    2
82     CVC-Ask-Timeout(4228)      4    0
83     IE-Proxy-Pac-URL(4229)      0    0x00007fff351ce1a4   ** Unresolved Attribute **
84     IE-Proxy-Lockdown(4230)      4    1
85     WebVPN Smart Tunnel(4232)      0    0x00007fff351ce1a9   ** Unresolved Attribute **
86     WebVPN ActiveX Relay(4233)      4    1
87     WebVPN Smart Tunnel Auto Download enable(4234)      4    0
88     WebVPN Smart Tunnel Auto Sign On enable(4235)      0    0x00007fff351ce1b2   ** Unresolved Attribute **
89     VLAN ID(4236)      4    0
90     NAC Settings(4237)      0    0x00007fff351ce1b7   ** Unresolved Attribute **
91     MemberOf(4241)      0    0x00007fff351ce1b8   ** Unresolved Attribute **
92     WebVPN Idle timeout alert interval(4244)      4    1
93     WebVPN Session timeout alert interval(4245)      4    1
94     Maximum object size for download(4253)      4    2147483647
95     Maximum object size for upload(4254)      4    2147483647
96     Maximum object size for post(4255)      4    2147483647
97     User storage(4256)      0    0x00007fff351ce1cd   ** Unresolved Attribute **
98     User storage objects(4257)     19    "cookies,credentials"
99     User storage shared key(4258)      0    0x00007fff351ce1e2   ** Unresolved Attribute **
100     VDI configuration(4259)      0    0x00007fff351ce1e3   ** Unresolved Attribute **
101     NAC Exception List(4312)      4    0
102     List of address pools to assign addresses from(4313)      0    0x00007fff351ce1e8   ** Unresolved Attribute **
103     List of IPv6 address pools to assign addresses from(4314)      0    0x00007fff351ce1e9   ** Unresolved Attribute **
104     IPv6 filter-id(4315)      8    ""
105     WebVPN Unix user ID(4317)      4    65534
106     WebVPN Unix group ID(4318)      4    65534
107     Disconnect VPN tunnel when a Smartcard is removed(4321)      4    1
108     WebVPN Smart Tunnel Tunnel Policy(4323)      0    0x00007fff351ce1fe   ** Unresolved Attribute **
109     Disable Always-On VPN(4325)      4    1
110     SVC ignore DF bit(4326)      4    0
111     SVC client routing/filtering ignore(4327)      4    0
112     Configure the behaviour of DNS queries by the client when Split tunneling is enabled(4328)      4    0
113     Client Bypass Protocol(4331)      4    0
114     IPv6-Split-Tunneling-Policy(4332)      4    0
115     Gateway FQDN(4333)      0    0x00007fff351ce217   ** Unresolved Attribute **
116     CA URL for SCEP enrollment(20530)      0    0x00007fff351ce218   ** Unresolved Attribute **
Auth Status = ACCEPT
AAA API: In aaa_close
AAA task: aaa_process_msg(0x00007fff28d327d0) received message type 3
In aaai_close_session (3)
I just checked the configuration and problem description and I read something different this time.
From your post:
This is not going to be possible unless any of the following feature is used:
1- Group-url
2- Group-alias
3- Certificate authentication + certificate mapping
If any of the above is not used, then there is no way to hit any other tunnel-group than the default one.
So, you need to make a decision and pick up one of those.
HTH.
Portu.
Hi Portu,
So basically there's no way we can use LDAP authetication to dynamically force the user to use a specific tunnel and this can only be done with group-policy?
thanks
Hi Mahdi,
Yes, that is correct.
Thanks.
Please do not forget to rate any helpful posts and mark this post as answered.
Hi Javier,
Same issue i am facing, kindly advice from below Logs:-
[7381] Session Start
[7381] New request Session, context 0x00007f29b06850c0, reqType = Authentication
[7381] Fiber started
[7381] Creating LDAP context with uri=ldap://xxx.xx.xx.xxx:xxx
[7381] Connect to LDAP server: ldap://xxx.xx.xx.xxx:xxx, status = Successful
[7381] supportedLDAPVersion: value = 3
[7381] supportedLDAPVersion: value = 2
[7381] Binding as xxxx@xyx.com
[7381] Performing Simple authentication for xxxx@xyx.com to xxx.xx.xx.xxx:xxx
[7381] LDAP Search:
Base DN = [DC=xxxxxx,DC=com]
Filter = [sAMAccountName=xxxxadmin]
Scope = [SUBTREE]
[7381] User DN = [CN=xxxxxx - Admin,OU=IT Administrators,DC=xxxxxx,DC=com]
[7381] Talking to Active Directory server xxx.xx.xx.xxx:xxx
[7381] Reading password policy for xxxxadmin, dn:CN=xxxxxxx - Admin,OU=IT Administrators,DC=xxxxxxxxxx,DC=com
[7381] Read bad password count 0
[7381] Binding as xxxxxxxxxx
[7381] Performing Simple authentication for xxxxadmin to xx.xx.xx.xxx
[7381] Processing LDAP response for user xxxxxadmin
[7381] Message (xxxxxxxxxx):
[7381] Authentication successful for xxxxxxxxxx to xx.xx.xx.xxx
[7381] Retrieved User Attributes:
[7381] objectClass: value = top
[7381] objectClass: value = person
[7381] objectClass: value = organizationalPerson
[7381] objectClass: value = user
[7381] cn: value = xxxxxxxxxx - Admin
[7381] sn: value = Mohd
[7381] description: value = xxxxxxxxxx - Domain Admin
[7381] userCertificate: value = 0...0..........7...]Z.P.|.`:.....]0...*.H........0U1.0.....&...,d....com1.0.....
[7381] userCertificate: value = 0...0..........7...\r............\0...*.H........0U1.0.....&...,d....com1.0.....
[7381] userCertificate: value = 0...0..........7...[,.R...T......[0...*.H........0U1.0.....&...,d....com1.0.....
[7381] userCertificate: value = 0...0..........7...W8@>..........W0...*.H........0U1.0.....&...,d....com1.0.....
[7381] givenName: value = Maitham
[7381] distinguishedName: value = CN=xxxxxxxxxx - Admin,OU=IT Administrators,DC=xxxxxxxxxx,DC=com
[7381] instanceType: value = 4
[7381] whenCreated: value = 20161208053848.0Z
[7381] whenChanged: value = 20200618055626.0Z
[7381] displayName: value = xxxxxxxxxx - Domain Admin
[7381] uSNCreated: value = 26223
[7381] memberOf: value = CN=Splunk Admins,OU=BHB Groups,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=WSAdmin,CN=Builtin,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=Helpdesk,CN=Users,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=Remote Desktop Users,CN=Builtin,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=Domain Admins,CN=Users,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=Administrators,CN=Builtin,DC=xxxxxxxxxx,DC=com
[7381] memberOf: value = CN=Recipient Management,OU=Microsoft Exchange Security Groups,DC=xxxxxxxxxx,DC
[7381] uSNChanged: value = 45324626
[7381] name: value = xxxxxxxxxx - Admin
[7381] objectGUID: value = ..qc1..N........
[7381] userAccountControl: value = 512
[7381] badPwdCount: value = 0
[7381] codePage: value = 0
[7381] countryCode: value = 0
[7381] badPasswordTime: value = 132365994235248758
[7381] lastLogoff: value = 0
[7381] lastLogon: value = 132374522322484840
[7381] scriptPath: value = itdfs.bat
[7381] pwdLastSet: value = 132369333859691240
[7381] primaryGroupID: value = 513
[7381] objectSid: value = ..............P....E...<....
[7381] adminCount: value = 1
[7381] accountExpires: value = 9223372036854775807
[7381] logonCount: value = 8617
[7381] sAMAccountName: value = xxxxxxxxxx
[7381] sAMAccountType: value = 805306368
[7381] userPrincipalName: value = xxxxxxxxxx@xxxxxxxxxx.com
[7381] lockoutTime: value = 0
[7381] objectCategory: value = CN=Person,CN=Schema,CN=Configuration,DC=xxxxxxxxxx,DC=com
[7381] dSCorePropagationData: value = 20200624130212.0Z
[7381] dSCorePropagationData: value = 20200624120212.0Z
[7381] dSCorePropagationData: value = 20200624110212.0Z
[7381] dSCorePropagationData: value = 20200624100212.0Z
[7381] dSCorePropagationData: value = 16010101000000.0Z
[7381] lastLogonTimestamp: value = 132368950203626481
[7381] Fiber exit Tx=584 bytes Rx=9698 bytes, status=1
[7381] Session End
