Traffic not routing between remotes using ezVPN with NEM
Matthew Spire
I've been scouring the forums for a while now looking for ways to fix this one but just can't find anything that helps.  I have ezVPN configured on an ASA 5520 for my server with 5505s as my clients at several remote sites.  The tunnels come up no problem and I can hit everything I need to on both sides of the tunnel, but I'm not able to get to another remote network from a remote network.  The traffic goes out the tunnel on the 5505 but on the 5520 all I see is a bunch of scrolling tear down messages.  Any thoughts would be greatly appreciated.
Hub side
interface GigabitEthernet0/0
nameif Inside_Network
security-level 100
ip address 10.0.0.1 255.255.255.252
interface GigabitEthernet0/3
nameif Outside_Network
security-level 0
ip address 192.168.32.8 255.255.255.0
same-security-traffic permit inter-interface
router eigrp 10
network 10.0.0.0 255.255.255.0
redistribute static
crypto ipsec ikev1 transform-set my-set esp-aes-256 esp-sha-hmac
crypto dynamic-map ezvpn 30 set ikev1 transform-set my-set
crypto dynamic-map ezvpn 30 set reverse-route
crypto map outside_map 65535 ipsec-isakmp dynamic ezvpn
crypto map outside_map interface Outside_Network
crypto ikev1 enable Outside_Network
crypto ikev1 policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
group-policy VPN_GP internal
group-policy VPN_GP attributes
vpn-idle-timeout none
nem enable
username vpnuser password Wj0QXCAEhK12A5Sp encrypted privilege 0
tunnel-group VPN type remote-access
tunnel-group VPN general-attributes
default-group-policy JEOD_VPN_GP
tunnel-group VPN ipsec-attributes
ikev1 pre-shared-key *****
Remote Side - Not much needed here
vpnclient server 192.168.32.8
vpnclient mode network-extension-mode
vpnclient vpngroup VPN password *****
vpnclient username vpnuser password *****
vpnclient enable
rohaverm
Remote EzVPN clients are able to connect to the Headend ASA5520 but cannot communicate among themselves. Is it correct understanding?
Are all the EzVPN clients terminated on different outside physical interface of the ASA? If not then we will have to permit traffic intra-interface too along with inter-inerface i.e. same-security-traffic permit intra-inerface.
rohaverm
You understood correctly.  They are all being terminated on the same outside interface and the intra-interface worked like a charm.  Thanks.  I knew it would be something simple in the end.
