Using AnyConnect to connect to multiple domains
JasonRendel
Hello:
I have a situation where I need to be able to regularly connect to two different domains over VPN using the AnyConnect solution.  The behavior I am seeing is that it is not as simple as changing the VPN address in the AnyConnect client.  The stats window shows Domain A as the Administrative Domain when connected to Domain B.
I am able to connect to Domain B for about 30 seconds before the connection drops and I lose internet connectiivity until I close the client.  Any help is greatly appreciated.
Jason,
It is good to know you were able to narrow down the issue to a DNS problem.
If you do not have any further questions, please mark this post as answered.
Thanks.
5 Replies 5
When you refer to Domain you talk about an AnyConnect profile / tunnel-group?
What error does the client report?
Thanks.
Portu
Sent from Cisco Technical Support Android App
I'm connecting to two different clients/companies that are using AnyConnect.  It seems that perhaps that is two different profiles, but I am not sure.
Jason,
We need to get more details.
Does the AnyConnect pop-up any error?
DART bundle file?
Does it happen from any location?
How often does it happen?
Does it happen to all machines?
OS x64 or x86?
Thanks.
Portu.
JasonRendel
Turns out the issue was related to a DNS issue on one of the client's ends.  The AnyConnect client appeared to connect but there was apparently a failure in the pipeline.  Using the IP address fixed the connectivity issue.
Jason,
Thanks.
