Using VPN client with Lan-to-LAN tunnel
srdjankatic
Hi collegues,
i have setup VPN tunnel between two 2801 routers with exact configuration i was provided. Problem started when i recieved requirement to allow one PC to connect to 2801 with CVPN client 5.0xxxx. Generaly, i have problem how to incorporate configuration for CVPN into existing LAN-to-LAN configuration that i cant change? I realize i have to create separate isakmp policy so i did but the rest is confusing. Separate transform-set? Separate acl? I dont know, i am not some expert on thi issue. Question is what else i need to add to configuration for this to work? I will paste existing config. Thank You!
andrew.prince
Level 10
Level 10
Tnx:) I will try it out, but i dont have access to VPN concentrator so i must not change any line in existing LAN-to-LAN config, just need to add lines for CVPN client.
Srkey
chandanake
Hi I'm Chandana,
we have a ASA5520 using ASDM we configured a IPSEC stit-to-site VPn tunnel now it is working properly.
so we want to add another device which ip is 172.16.255.7 & our another site ip also same(172.16.255.7)
so I want to using group policy nat
our side ip 172.16.255.7--> 192.168.62.1
remote site ip 172.16.255.7--> 192.168.62.10
but both side uses can access this 172.16.255.7 as a local server
so Please help me to do this nat
