VPN Client Connectivity Problem
scottkeegan
Hi there, I have a issue with the latest client on Windows XP and it will not connect. Other machines connect ok but when this one tries it gets an error in the log. It is as follows:
Unable to establish Phase 1 SA with server "***.***.***.***" because of "DEL_REASON_PEER_NOT_RESPONDING"
Any help on this would be great. Thanks
smahbub
Level 6
Level 6
Make sure that you don't have any personal FW configuration on your PC, i.e. the built in Personal FW. In addition, you may want to try the v3.5 client available from the CCO SW. Center to see if it makes any difference, but it really shouldn't. You should be able to set the MTU back to the system default and the VPN client should adjust what it needs to.
