VPN Client works with Ethernet & WiFi but not Mobile Broadband on T410
robert.green
I have a new Lenovo T410 with Windows 7 Pro (32 Bit). I installed the VPN client 5.0.07.0290. I works on my Ethernet and my WiFi connections but will not work using the inbuilt Mobile Broadband Card (Qualcomm Gobi 2000 HS-USB Mobile Broadband Device 9205) and the Access Connections software on the Lenovo to connect (As with WiFi). It says connected but I can't even ping anything. Where do I start to work out what is going on?
This used to work when I had my Telstra USB 3G modem on my Dell XP Laptop.
Help
RG
Todd Pula
Level 7
Level 7
Wireless data cards are not supported with the latest 5.0.07 client and Windows 7 32-bit and 64-bit.  The AnyConnect SSL client will be your only option.  Please refer to the "New Features" section in the VPN Client release note below.
http://www.cisco.com/en/US/partner/docs/security/vpn_client/cisco_vpn_client/vpn_client5007/release/notes/vpnclient5007.html#wp101224
Todd,
thanks for your response.Can I import the existing PCF file the we use into AnyConnect SSL?
Robert
