VPN issue when local lan IP matches Corp LAN IP
michael.white
I am having an issue accessing corporate services when an IP for example of one of our servers matches an IP address of a local host from the LAN the user is accessing from.
Is there any way to work around and or resolve this?
I am using split tunnel, I am sending all DNS lookups through tunnel, and assigning the DNS name.
I inherited this network that is a 192.168.0.0/23 with a lot of the services on 192.168.1.x which easily match private local lans.
18 Replies 18
Network object NAT was the only place I found that command as well, is that the only/best to do it 8.3 +?
Looks like if we already have 1to1 NAT configured this command will not work, is that correct?
Looks like the only option will be to configure a DNS server to service this VPN specifically. Thanks for comments!
Thanks for posting Michael,
Please rate any helpful post.
Portu.
