VPN Site to site ASA 5550 -> 5506-X - Problem
dorcejose
Hello everyone!
I'm having some problems setting up a vpn tunnel between two cisco Asa's.
The scenario is as follows
One Asa 5506 (My side) and one 5550 (other side).
Tunnel properties are as follows :
Phase 1
Auth : Pre-shared key
Encryp : Ike
Group 2
Encrypt : 3DES
Hashing : SHA1
Main Mode Only
Timelife 86400
Phase 2
Encapsulation : ESP
Encrypt : AES128
Authentication ESP : NO
Authentication AH : SHA-1
PFS : NO
Timelife 3600
Host on my side is 10.1.2.198 and the remote side 10.112.8.34.
Now , the problem:
Phase 1 is completed successfully. But Phase 2 NO.
Try setting through the wizard(GUI ASDM) and through the console CLI. But the same problem occurs:
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, PHASE 1 COMPLETED
[IKEv1]IP = 190.30.233.52, Keep-alive type for this connection: DPD
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, Starting P1 rekey timer: 82080 seconds.
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Add to IKEv1 Tunnel Table succeeded for SA with logical ID 589824
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Add to IKEv1 MIB Table succeeded for SA with logical ID 589824
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, IKE got SPI from key engine: SPI = 0x7c37d268
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, IKE got SPI from key engine: SPI = 0x50859caf
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, oakley constucting quick mode
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing blank hash payload
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing IPSec SA payload
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing IPSec nonce payload
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing proxy ID
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, Transmitting Proxy Id:
Local subnet: 10.1.2.0 mask 255.255.255.0 Protocol 0 Port 0
Remote subnet: 10.112.8.0 Mask 255.255.255.0 Protocol 0 Port 0
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing qm hash payload
[IKEv1]IP = 190.30.233.52, IKE_DECODE SENDING Message (msgid=ad5e593a) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 248
[IKEv1]IP = 190.30.233.52, IKE_DECODE RECEIVED Message (msgid=5b7b1393) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 304
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, processing hash payload
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, processing notify payload
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Received non-routine Notify message: Invalid ID info (18)
[IKEv1]IP = 190.30.233.52, IKE_DECODE RECEIVED Message (msgid=c62d4d1e) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, processing delete
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Connection terminated for peer 190.30.233.52. Reason: Peer Terminate Remote Proxy 0.0.0.0, Local Proxy 0.0.0.0
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Remove from IKEv1 Tunnel Table succeeded for SA with logicalId 589824
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Remove from IKEv1 MIB Table succeeded for SA with logical ID 589824
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, sending delete/delete with reason message
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, constructing IPSec delete payload
[IKEv1]IP = 190.30.233.52, IKE_DECODE SENDING Message (msgid=e8f0164b) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 68
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, IKE Deleting SA: Remote Proxy 10.112.8.0, Local Proxy 10.1.2.0
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Removing peer from correlator table failed, no match!
[IKEv1 DEBUG]Group = 190.30.233.52, IP = 190.30.233.52, IKE SA MM:5af65f62 terminating: flags 0x0100c822, refcnt 0, tuncnt 0
[IKEv1]Group = 190.30.233.52, IP = 190.30.233.52, Session is being torn down. Reason: User Requested
Settings on my side :
access-list vpn_traffic extended permit ip host 10.1.2.198 host 10.112.8.34
nat (inside,outside) source static obj-local obj-local destination static obj-remote obj-remote
crypto ipsec ikev1 transform-set ESP-AES128-SHA esp-aes esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map VPN-MAP 1 match address vpn_traffic
crypto map VPN-MAP 1 set peer 190.30.233.52
crypto map VPN-MAP 1 set ikev1 transform-set ESP-AES128-SHA
crypto map VPN-MAP interface outside
crypto ca trustpool policy
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 190.30.233.52 type ipsec-l2l
tunnel-group 190.30.233.52 ipsec-attributes
ikev1 pre-shared-key *****
Maybe I'm not setting the parameters well. It's very frustrating..
I hope I can guide. Thank you very much
Michael Muenz
Level 5
Level 5
Have you tried to replace the host values in the ACL with subnets?
Michael Please rate all helpful posts
Thanks for the quick reply!!. That probe in different ways, but still the problem.
