08-16-2001 06:05 AM - edited 02-21-2020 11:23 AM
I have a VPN using a "PIX to PIX" and "PIX to VPN Clients". I am able to get "PIX to PIX" working along with ver 1.1 of the client but not version 3. I can get version 3 and version 1 working together by swapping around the order of the crypto map statements but then the "PIX to PIX" connection won't come up. Has anybody implemented a VPN with PIX and both clients?
08-16-2001 07:03 AM
Yes I am doing it now. All I had to do to get Version 3.x working was to add the vpngroup statements. Here is the template I use for PIX to PIX and Client to PIX:
access-list 80 permit ip 192.168.1.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list 80 permit ip 192.168.2.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list 80 permit ip 192.168.3.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list 80 permit ip 192.168.0.0 255.255.0.0 192.168.200.0 255.255.255.0
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list 101 permit ip 192.168.2.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list 101 permit ip 192.168.3.0 255.255.255.0 10.1.0.0 255.255.0.0
nat (inside) 0 access-list 80
ip local pool vpnpool 192.168.200.1-192.168.200.254
sysopt connection permit-ipsec
crypto ipsec transform-set vpn3-set esp-3des esp-md5-hmac
crypto dynamic-map remote 20 set transform-set vpn3-set
crypto map vpn-map 18 ipsec-isakmp dynamic remote
crypto map vpn-map 20 ipsec-isakmp
crypto map vpn-map 20 match address 101
crypto map vpn-map 20 set peer xxx.xxx.xxx.xxx
crypto map vpn-map 20 set transform-set vpn3-set
crypto map vpn-map client configuration address initiate
crypto map vpn-map interface outside
isakmp enable outside
isakmp identity hostname
isakmp client configuration address-pool local vpnpool outside
isakmp policy 1 authentication rsa-sig
isakmp policy 1 encryption 3des
isakmp policy 1 hash sha
isakmp policy 1 group 1
isakmp policy 1 lifetime 86400
These are the command I added for Win2K support on client version 3.x:
vpngroup NY address-pool vpnpool
vpngroup NY dns-server 10.1.1.4
vpngroup NY default-domain whatever.com
vpngroup NY split-tunnel 80
vpngroup NY idle-time 1800
vpngroup ny idle-time 1800
I hope this helps you. I got most of this from the config examples on this site
Pete
08-17-2001 02:13 AM
Thanks for the repsonse Pete. It seems the trouble we're having stems from the fact that we're using 56-bit DES rather than 3DES. The VPN Client 3.0 supposedly supports 56-bit DES but in actual fact although the VPN tunnel is established the return packets are not being decrypted resulting in a high number of dumped packets. One workaround I guess is to move to 3DES although this seems like overkill.
08-16-2001 09:17 AM
Also, if you deal with different client versions, make sure you have different policies on PIX. You can have more than you need, it doesn't hurt. See Security Tech Tips for how to configure PIX 6.01 with 2 versions of clients.
08-22-2001 02:07 AM
I got the VPN working with PIX to PIX and PIX to VPN Clients (both versions). During my testing I had used ping to verify connectivity. It seems that using icmp as test traffic caused issues with VPN Client ver 3.0 with traffic not being properly encrypted and decrypted. Once I tested using tcp based traffic I found ecerything worked as expected.
