WAP321 Guest Network will not supply IP to wireless devices.
Tim-Fulton
Have a WAP321 connected to a Cisco SG200-08P then connected to a Cisco 2901.  The main wireless on vLAN 1 works fine.  However, the Guest on vLAN 4 (Choose vLAN 4 as per the included docs so guests will be unable to see the production network) will not give an IP to any wireless device.
Looking for documentation, suggestions, assistance on getting the Guest radio working.  The included documention for these 3 devices do not address how to get the Guest radio to work.
Does vLAN 4 need setup on the 2901? Have just 1 internal port on the 2901...
THANKS!
15 Replies 15
Hi Tim,
So the way i understood this is only the DHCP is not working for VLAN4 and when you assign static ip it work?Is this right? Where is the DHCP running for VLAN 1? Is it on the same router?
Could you please share the entire router configuration with sensitive infomrations removed?
Najaf
Please rate when applicable or helpful !!!
