Weird thing going on with ASA and RDP through filtered VPN
Broker_2
I'm hoping to get some support over here as i'm clearly out of options.
I have 3 ASA 2 5505 and one 5510
all of them are connected over the internet by VPN
one 5505 is on my premisis and I use the VPN to service the other 2 locations that belong to the same customer. Clearly I want to filer the VPN going to the other locations aswell as traffic comming from them.
the strange thing is if I put an IP any any on the filter acl I can use RDP, at the moment I enforce the filter where I enable TCP/3389 I get an error that the server cannot be found.
in the logging i see the packet hitting the ACL:
<167>:Jul 05 21:13:19 CEDT: %ASA-session-7-106102: access-list VPN_Filter permitted tcp for user '<unknown>' User-Lan/192.168.1.87(58603) -> XS4ALL/172.31.2.12(3389) hit-cnt 1 first hit [0xbe2548e2, 0x0]
<166>:Jul 05 21:13:19 CEDT: %ASA-session-6-302013: Built outbound TCP connection 43436 for XS4ALL:172.31.2.12/3389 (172.31.2.12/3389) to User-Lan:192.168.1.87/58603 (192.168.1.87/58603)
VPN Filter:
access-list VPN_Filter extended permit ip any any log debugging inactive
access-list VPN_Filter extended permit object RDP object-group DM_INLINE_NETWORK_8 object Lan-Pat
access-list VPN_Filter extended permit udp object-group DM_INLINE_NETWORK_4 object Lan-Pat eq tftp
access-list VPN_Filter extended permit icmp object-group DM_INLINE_NETWORK_1 object Lan-Pat log debugging
access-list VPN_Filter extended permit tcp object-group DM_INLINE_NETWORK_3 object Lan-Pat eq www
access-list VPN_Filter extended permit tcp object-group DM_INLINE_NETWORK_5 object Lan-Pat eq https
access-list VPN_Filter extended permit tcp object-group DM_INLINE_NETWORK_6 object Lan-Pat object-group DM_INLINE_TCP_1
access-list VPN_Filter extended deny ip any any log debugging
any help will be greatly appriciated!
if you do an RDP-session from your PC to the customer, then port TCP/3389 is used on the customer-side and not on your side. So your ACL has to be the following:
access-list VPN_Filter extended permit tcp 172.31.2.0 255.255.255.0 eq 3389 192.168.1.0 255.255.255.0
Remember: In a VPN-Filter the syntax is source=remote, destination=local. The port 3389 is on the remote end.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
6 Replies 6
The vpn-filter is using a different syntax then a regular ACL. It is:
permit/deny PROTOCOL REMOTE-IP eq REMOTE-PORT LOCAL-IP eq LOCAL-PORT
So if you want to allow RDP from your side to the customer, your VPN-Filter has to be the following:
access-list VPN_Filter extended permit tcp host CUSTOMER-IP eq 3389 host YOUR-IP
Hello Karsten,
Thank you for your post.
this line:
handles the RDP as DM_INLINE_NETWORK_8 is the client side and the lan_pat is my local side.
do you have any other thoughts what could cause the problem?
please clarify where the RDP-Server is and where the RDP client. And post the relevant lines from "show access-list VPN_Filter" and not from "sh run ...".
Hello Karsten,
These are the requested lines
192.168.1.x/24 is my local lan.
I want to make a RDP session from my PC (192.168.1.x) to a server on the customer lan for example 172.31.2..x
access-list VPN_Filter line 2 extended permit object RDP object-group DM_INLINE_NETWORK_8 object Lan-Pat 0x7a06853d
  access-list VPN_Filter line 2 extended permit tcp 192.168.5.0 255.255.255.0 range 1 65535 192.168.1.0 255.255.255.0 eq 3389 (hitcnt=0) 0x6dbbab46
  access-list VPN_Filter line 2 extended permit tcp 172.31.2.0 255.255.255.0 range 1 65535 192.168.1.0 255.255.255.0 eq 3389 (hitcnt=0) 0x4fede2a3
  access-list VPN_Filter line 2 extended permit tcp 10.255.2.0 255.255.255.0 range 1 65535 192.168.1.0 255.255.255.0 eq 3389 (hitcnt=0) 0xf63149ed
  access-list VPN_Filter line 2 extended permit tcp 192.168.0.0 255.255.255.0 range 1 65535 192.168.1.0 255.255.255.0 eq 3389 (hitcnt=0) 0xf6c544e9
Thanks mate,
that did the trick!
