Will changing SSL setting affect IPsed site to site VPN current configuration ?
networkadwea
I'm planning to modify SSL setting on ASA appliance ( TLS1.2 = Custom cipher) , so will this affect my currenty IPsec site to site VPN tunnels? any impact to this? as far as i know it must not affect since VPN has IPSec proposal seperate
Appreciate your supprot on this
No, changing the TLS settings should not impact an IPSec VPN.
Beware you might have an issue connecting to ASDM, so you may need to upgrade your java.
