ACL Cisco IOS help
tschaefer
Frequent Visitor
Frequent Visitor
I have an ACL on a VLAN interface which is used for wired Guest access.
The device is given a IP address in the Guest range I want to deny access to internal networks and allow Internet only access
Problem is the following Access list in not working correctly
Extended IP access list Internet-Only
    10 permit udp any any eq domain
    20 permit tcp any any eq domain
    30 permit udp any eq bootps any
    40 permit udp any any eq bootpc
    50 permit udp any eq bootpc any
    60 permit ip any host 10.129.40.127
    70 permit ip any host 10.129.36.80
    80 deny ip any 10.0.0.0 0.255.255.255 (12 matches)
    90 deny ip any 172.16.0.0 0.15.255.255
    100 deny ip any 192.168.0.0 0.0.255.255
    110 permit ip any any (1759 matches)
The host receives an IP address of 10.129.88.x and cannot ping out to 8.8.8.8 or internally as you can see it hits the first Deny rule.
The ACL is applied to the vlan interface for guest for outbound traffic. No inbound ACL is applied to the VLAN
i.e
interface vlan 100
ip access-group ACCESS-list out
What am I missing here ?
Appreciate the feedback
Tim
David Hild
Level 8
Level 8
I'm not sure of the reference point for the data, but it seems to me that you need a "ip access-group ACCESS-list in" on the VLAN interface. That is, assuming your VLAN 100 is the VLAN that your endpoint is a member of. The fact that the UDP entries do not show any hits, yet the endpoint received an IP may be an indication of this.
I could be wrong and completely misunderstanding your network, but it's worth a try, IMHO.
I hope this is helpful.
David Hild
Level 8
Level 8
