Block HTTPS on ASA (Standard ASA no other features)
#TCN
Level 3
Level 3
is it possible to block specific https URL's on a standard ASA using the "regex" (regular expression) - I believe the customers ASA is running version 9.x
I had a look around the regex and looks like you can only block http and not https
James
2 Accepted Solutions
Dinesh Moudgil
Hi James,
HTTPS filtering is not supported on ASA. ASA cannot do deep packet inspection or inspection based on regular expression for HTTPS traffic, because in HTTPS, content of packet is encrypted (SSL).
Reference:-
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/100535-asa-8x-regex-config.html
Dinesh Moudgil
P.S. Please rate helpful posts.
Cisco Network Security Channel - https://www.youtube.com/c/CiscoNetSec/
ASA (with Sourcefire) will be able to analyze HTTPS traffic and block/allow it based on policy you configure - HTTPS decryption is coming with next major version.
You can use Cisco Web Security appliance along with Cisco ASA today to filter HTTP and HTTPS traffic.
Dinesh Moudgil
Hi James,
Reference:-
Dinesh Moudgil
Thanks Dinesh - much appriciated.
James
The FirePOWER release 6.0.0 which includes SSL-Inspection on the local box was released two days ago. But as with any X.0.0 version, I first would use it in a test-system.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
