Bypass decryption
manoj.m5311
Community Member
How Bypass decryption helps in accessing the website that blocked by the Proxy.
keglass
Level 11
Level 11
Manoj,
I am moving your post to the Security Community for better visibility and access to feedback.
Email and Web Security
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
Web Usage policies can be applied effectively when decryption is enabled, as WSA can get visibility of the traffic when decrypted. You will also get advantage of checking files and taking action on those files if you decrypt HTTPS sites.  You can also exempt required web categories to bypass from decryption. For example, some financial sits may not work properly when decrypted.
