Cisco vWSA not accessible on browsers
Asfandyar70754
Hey guys,
So I am trying to use Cisco vWSA on Vmware for practice but for some reason it is not accessible on browsers.
Earlier I tried Cisco vSMA and was able to access it on chrome & edge but vWSA is not accessible on any of the browser. I am able to ping it but for some reason it is not accessible on the browser.
@Asfandyar70754 when you run through the initial configuration on the CLI did you enable http and https? You can re-run this using interfaceconfig then to connect to the management interface using a hostname (http://hostname:8080)
@Asfandyar70754 what interface IP address are you attempting to connect to? M1?
From the CLI it will tell you the IP address and port (8080) to connect to for mgmt.
Have you configured the gateway on the WSA?
I have assigned IP address 192.168.63.221 and I have set gateway 192.168.63.1.
yes I am trying to access it using this IP but it is not accessible but it is pingable.
Thanks a lot Rob.
I didnt enable HTTP and HTTPS.
