09-12-2014 11:01 AM
Connection refused error showing in ironport s170 - WSA
I am getting “Connection refused” error while I connect ironport s170 through console cable. also i am not able to connect it through HTTP and SSH. Complete output is given below.
Last login: Thu Sep 11 07:16:59 on cuad0
Copyright (c) 2001-2011, Cisco Systems, Inc.
AsyncOS 7.5.2 for Web build 303
Welcome to the Cisco IronPort S170 Web Security Appliance
Traceback (most recent call last):
File "/usr/build/iproot/ap/ipoe/ipoe/bootstrap.py", line 55, in <module>
File "/data/lib/python2.6_7_i386_nothr/runpy.py", line 128, in _run_module_as_
main
"__main__", fname, loader, pkg_name)
File "/data/lib/python2.6_7_i386_nothr/runpy.py", line 34, in _run_code
exec code in run_globals
File "build/bdist.freebsd-7.2-RELEASE-p2-i386/egg/cli.py", line 426, in <modul
e>
File "build/bdist.freebsd-7.2-RELEASE-p2-i386/egg/external_auth/__init__.py",
line 212, in initialize
line 118, in _setup_old_authentication
File "build/bdist.freebsd-7.2-RELEASE-p2-i386/egg/command_client.py", line 674
, in quick_read_var
File "build/bdist.freebsd-7.2-RELEASE-p2-i386/egg/command_client.py", line 133
, in connect
Commandment.CommunicationError: <host name>: Network communication error
: Connection refused
AsyncOS <host name> (cuad0)
login:
09-15-2014 03:46 PM
You can upgrade to 7.7+ but if you require a root cause analysis I suggest you to open a TAC case.
Luis Silva
07-03-2015 04:08 AM
HI luis,
i am not able to login properly, then how can i upgrade it.
It will exit after showing "connection refused" error showing after login to the console.
05-24-2017 04:28 AM
Hello Friend
I had the same problem with C150
Did you succeed in defeating it?
