Failover using the PAC file
wkw.bcdomain
Is it possible to failover traffic in explicit proxy mode ( without using a dedicated  load balancing appliance ) ?
I have seen some PAC file scripts to load balance the traffic between 2 Proxy servers.
but it seems that they are not capable of handling the failover in case of a failure one one proxy server.
As per the testing I did, the clients still attempt to connect the failed appliance since they are not aware about the failure.
PC Tiya
HI Wipula
You may try return 2 proxy servers at the end of the PAC file
        return "PROXY proxy1.domain:8080; PROXY proxy2.domain:8080";
The browser will work that out itself. This will provide you failover from the client side.
If you want to load balance the proxy servers, without using any load-balancer, you may
round-robin/randomly return those 2 proxy servers in different order.
Hope this help
pt
Hi Prachid,
Thank you for your response.
I tested it just now with the information provided.
According the packet capure, the browser still attempts to connect to the failed proxy servaral times.
After few failed attempts it sends the traffic to the other proxy.
The browser does this every time so it takes long for a user to get a response.
have you used this setup before and got better outcome ?
The browser I am using is Internet explorer 8.
Wipula.
Yes. The browser should keep trying the first proxy. If it failed, it will try the second one.
In our environment, the browsers take a brief seconds before trying the second proxy server.
I have seen some issues with IE9, not sure for IE8.
Have you tried that on other browsers e.g. Chrome, Firefox?
From my experience, a fail over design via a PAC/WPAD file does not work very well.  If the proxy blocks the request using a 403, the client will assume this failed, and try the 2nd option.
-Vance
