Gateway for P1 and P2
I would like to set different gateway for M1, P1 and P2 in WSA
Is that possible?
How it is configured?
Thanks and regards,
Konstantinos
5 Replies 5
Hi @kostasthedelegate
Yes this is possible. Each interface would be physically connected to a different VLAN and you specify the relevant default gateway. The WebUI location is network > interfaces tab.
You can set default gateway for each interface as well any static routes you need on the Network/Routes page.
Ok
So I cannot have a separate gateway for P1 and a separate for P2?
The thing is that I have P1 and P2 with different gateways, but I cannot seem to be able to set them.
For data traffic there is one routing table, but you can set for instance a route for RFC1918 adresses to the gateway of P1 and a default route to the gateway of P1.
