Guest Authentication issue
vaib7av.shirkul
Level 3
Level 3
I am using IronPort S160 ( 6.3). I am facing issue related Guest policy,
AD authentication is working properly, but when I typed incorrect password, it is not using guest policy, and URLs are allowed,
even I blocked in policy , pl check attachment for configuration.
Erik Kaiser
Hi vaib7av.shirkul,
I can see that you have only port 21 allowed in your guest access policy. Try adding port 80 and 443 to the guest access policy. Also if that does not help I would recommend opening a ticket with the Cisco Content Secuirty Team.
Sincerely,
Erik Kaiser
WSA CSE
WSA Cisco Forums Moderator
Sincerely, Erik Kaiser WSA CSE WSA Cisco Forums Moderator
