Guidance for Virtual WSA with SMA Deployment
MSN
I have a requirement to deploy redundant WSA with SMA. Below are the licenses which i have.
WEB-SEC-SUB – Cisco Web Security XaaS Subscription – 1
WSA-WSP-LIC – Web Advantage SW Bundle (WREP+WUC+AMAL) License – 1000
WSA-AMP-LIC – WSA Advanced Malware Protection License – 1000
SMA-WMGT-LIC – SMA Centralized Web Management Reporting License – 1000
SVS-WEB-SUP-B – Basic Support for Web Security – 1
Can anybody help me with the following queries?
We plan to have 2× WSA and 1× SMA ---- are the above licenses sufficient for this setup?
Does WSA and SMA require a separate VM license?
From these license details, how many users are covered/considered?
Based on these licenses, how should the sizing be done? Which equivalent VM spec should we select — S100V, S300V, or S600V?
Any guidance would be greatly appreciated
So there is some sales nuance that you'll want to double check with a Cisco sales guy, but...
That does look sufficient for what you want to do.
WSA and SMA are separate vm licenses, at this point its all SmartLicensing, so you provision that, then deploy the VMs and point them at the SmartLicense site.
That looks like 1000 users.. with virtual WSAs you can spin up as many as you need to cover your load. You may be able to get away with a single 600, but I'd spin up 2, and set them up for load balancing/HA... I used transparent redirection via WCCP from my firewalls, but you can do it with explicit redirection and the built in HA stuff too.
amojarra
Hello @MSN
As Ken mentioned, the licenses are different, so you need to get WSA licenses and the SMA license as well.
regarding the installation of the WSAs and the SMA:
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/vmware-esxi-cisco-ucs/222580-install-secure-web-appliance-on-vmware-e.html
https://www.cisco.com/c/en/us/support/docs/switches/vsg-microsoft-hyper-v/222581-install-secure-web-appliance-on-microsof.html
https://www.cisco.com/c/en/us/support/docs/security/web-security-appliance-s690x/222554-configure-secure-web-appliance-initial-s.html
you need to make sure the SMA and WSAs are in the compatible version:
https://www.cisco.com/c/dam/en/us/td/docs/security/security_management/sma/sma_all/web-compatibility/index.html
Also it is best to check the release notes, to review the known and fixed issues in the version you are choosing:
here are the links to the relevant release notes:
Secure Web Appliance (WSA) Release Notes: WSA Release Notes
Secure Email and Web Manager (SMA) Release Notes: SMA Release Notes
  • the Model S100-S300-S600 depends on:
    Number of active users
  • Decryption rate
  • Scanning engines
  • Scanning conditions
  • Requests per seconds
Also please allow me to share :
https://www.cisco.com/c/en/us/support/docs/security/secure-web-appliance/220375-use-secure-web-appliance-best-practices.html
this for sure will come in handy
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
