how to setup certificate for HTTPS proxy on WSA
jiyoung Kim
Level 3
Level 3
Hi, I'm trying to install the certificate for HTTPS Proxy on WSA.
the environment is not using private CA so no options for this.
I was going to use third party certificate like verisign, but they don't allow to use 1024 bit CSR which WSA is generating.
then, I have only option to upload certificate and key.
I have trusted certificate, but do not have the matched key. is there anyway I can get it ?
also, the certificate has to be a signing certification, is that mean the certificate is root certificate or trusted certificate ??
then How do I get the key for it ?
Thank you.
donnylee
The certificate required in the WSA for HTTPS proxy is root certificate.
Please see the previous discussion about the same topic
https://supportforums.cisco.com/discussion/11723386/how-setup-ssl-certificate-ironport-wsa
Donny
Artur Nowicki
Posted already in some other thread, but repeating here.
You could try the following steps (with openssl):
Generate the key:
openssl genrsa -des3 -out cakey.pem 2048
Generate the certificate (Valid for 10 Years):
openssl req -new -x509 -extensions v3_ca -key cakey.pem -out cacert.pem -days 3650
Remove the passphrase from the key:
openssl rsa -in cakey.pem -out cakey_nopass.pem
Later the certificate (cacert.pem) and key (cakey_nopass.pem) may be imported on the WSA.
Be aware about the performance impact caused by 2048bit certificate. It may influence it a lot.
BR,
Artur
I assume the openssl commands are to create self-signed certificate. in order not to show endusers certificate error, I have to deploy this certificate. there is no way to do it.
Thats why I came up with getting signed by public certificate authorities such as verisign, commodo, and so on.
However, I figured the public certificate authorities does not sign as root certificate.
