HTTPS management certificate
I would like to ask if there is a way to see when the management (gui) certificate is expiring.
From cli or gui
Is there a way to create an alert ?
Thanks and regards,
Konstantinos
9 Replies 9
Marvin Rhoads
For what product?
WSA
Marvin Rhoads
Easiest way is to just examine it in your browser toolbar when you go to the WSA.
I'm pretty sure there is already an alert built in.
You can see it under Network/Certificate management, the Appliance Cert is the one for the gui.
For the proxy, it's cert is under Security Services/HTTPS Proxy.
Hello
Then sth is wrong, because I install it through CLI, but I do not see it in the gui
Did you commit after making the cli change?
Yes and I see the cert is renewed but I get this error
inside the cert
Key usage should include those fields. The Yellow ! in a triangle is normal and should not prevent the certificate from working.
Hello Marvin,
Good to know about the key usage.
The issue was with CSR was missing an extra field.
Konstantinos
