HTTPS redirection does not work for WCCP and WSA
CSCO11942440
Community Member
Dear all
I would like to test a WCCP and WSA feautre. You can see my topology below.
Transparent redirection for HTTP(80) works as charm, but I have problem which HTTPS(443)
Explicite services works normaly.
When I check show ip wccp 90 detail I see counter for Redirected Packets grow up when I am trying HTTPS  from host.
WCCP Client information:
WCCP Client ID: 10.10.0.2
Protocol Version: 2.01
State: Usable
Redirection: L2
Packet Return: L2
Assignment: MASK
Connect Time: 01:18:51
Redirected Packets:
Process: 0
CEF: 0
Platform: 3958
GRE Bypassed Packets:
Process: 0
CEF: 0
Mask Allotment: 32 of 32 (100.00%)
Assigned masks/values: 1/32
Configuration for WCCP on CSR
ip wccp source-interface GigabitEthernet1
ip wccp 90 redirect-list 110
interface gi 1
ip wccp 90 redirect in
Extended IP access list 110
10 permit tcp 10.30.0.0 0.0.0.255 any eq www
20 permit tcp 10.30.0.0 0.0.0.255 any eq 443
WSA
I setup L2 forwarding/return method, I checked it for gre alsow.
Tao Yang
Have you had HTTPs proxy enabled in WSA GUI>Security Services?
Tao
Yep it works now...
I have a additional question. When configure NAT and WCCP it not works..Do you have some tips for this ?
Glad to hear it worked. Can  you please be more specific about NAT and what exactly is not working as expected? If WSA somehow could not know the real source IP, then it will not be able to response the client properly.
