import issue for Ironport S160
kristvandaele
I am trying to figure out a why to load a config file from another S160 in to a new one, but keep getting error during import:
Configuration File was not loaded. Parse Error on element "prox_config_auth_realm_ldap_group_filter_query" line number 3397 column 65 with value "(objectclass=groupofnames)": Value should consist of one or more components of the form 'object=value' where 'object' is composed of only alphanumeric characters and 'value' is composed of only the following set of characters (alphanumeric, -, _, space, `, ~, !, #, $, %, ^, &, (, ), {, }, @, ', ., \, /, [, ], :, |, =, *, ?, <, >, "). Multiple components are separated by a comma without spaces in between.
Just want to modify configuration of other site, and change IP addresses, but keep all other information of Ironport.
Thanks for your help in this !
Krist
dawaller
Krist,
Are the AsyncOS versions between the devices tha same?  They need to be the same in order to load a configuration file.
Dan
