Iron port single sign issue
igbinosuneric
Hello
i have integrated the WSA with active directory
configured single sign on
but Microsoft lync still prompts for authentication
please what  can i do to resolve this
thanks guys
I'm going to make some assumptions:
  • You're using Lync in the cloud
  • Lync is running at startup
  • the user hasn't opened any web page yet.
  • The prompt is web access related, NOT the actual lync login.
Try this for me. Exit Lync, use a browser and hit an external web page.  Start Lync (with or without the browser open, doesn't matter).  It should work...
The issue is that Lync can't handle the web auth request (Outlook can't either).
You have 2 options.
  • Figure out which user-agent string Lync is using and create an identity in the WSA for it, and a policy that doesn't require auth for that user-agent.
  • Deploy a CDA so that logins are picked up from the domain controllers and passed to the WSA before the users session actually gets to the point where its needed.
5 Replies 5
You have 2 options.
hello ken
thanks for the reply
by any chance, would you know the agent used by microsoft lync
doing my research and am coming up short
thanks
Useragent string looks like this:
UCCAPI/15.0.4420.1017 OC/15.0.4420.1017 (Microsoft Lync)
the version numbers vary depending on your version, obviously.
Look at the screenshots on how to find it (In the second image, the version is the first number within the brackets, meaning 15.0.4481.1000)
Hello all
I configured the ip addresses of the Lync servers in a custom URL
configured a identity which referenced the custom url
then in the global decryption policy i configured a pass through function for the custom URL
and that was it
look here: http://lmgtfy.com/?q=lync+user+agent
You can use regex for the agent string, so "\(Microsoft Lync\)" ought to work.
