Ironport URL routing - possible?
I have to first confess to not being very proxy aware (pardon the pun) so apologies if this is a silly question.
We currently have a unique challenge that I was hoping Ironport might be able to solve.  What we want to do is dedicate some bandwidth (at the internet edge) for a particular URL.  Currently all URLs are proxy'd to the same IP and therefore all inbound traffic must be treated equally.
What I was hoping to do is design a solution whereby the Ironport has 2 NICs; General traffic will flow over NIC1, and specific URLs will flow over NIC2.  This allows me to NAT the addresses to different IPs and dedicate bandwidth for "special" URLs, while at the same time utilising the same hardware.
An even better solution for me would be if we could create 2 virtual instances on the Ironport.  We could then have seperate entries in our pac file pointing to the 2 NICs.
Are either of these possible?
Colin Ritchie
Chris Illsley
Level 3
Level 3
Hi Colin,
You can't specify routes via URLs as such, but if you know the IP addresses it is possible by defining routes, eithe rin the Network - Routes tab or using routeconfig from the CLI.
Chris
Colin,
You don't mention what URLS you want bandwith limited, but if its the typical streaming apps (Hulu, Netflix, YouTube, etc.) look at the Application Visiblity and Control stuff.   You can pick and chose by application.
On a current hardware box, you can't set up "instances" on the box, but you should be able to get the VM version of Ironport and then you can set up as many virutal Ironport boxes as you want...
Ken
Thanks for your feedback.
What we are actually looking to do is dedicate bandwidth for SaaS applications.  We want to mark the traffic without relying on IP addresses; as SaaS deployments increase this won't be very managable.
Virtual Ironports looks like a great option, and the cost model looks good.  Another option might be Next Gen Firewalls to mark the traffic at Layer 7 towards the internet.
Maybe we can even write a policy that marks the DSCP value based on the URL?
Colin
