Layer 4 Traffic monitoring
Just want to ask the proper way to deploy layer 4 monitoring for Ironport WSA, so below is the diagram.
Lets say the switch has 5 available ports. From fa0/3 to fa0/7.
Do I just use Duplex mode and Tap a line from T1 to the switch? eX. T1 of Ironport to fa0/3
Or use Simplex mode? ex T1 to Fa0/3 then T2 to Fa0/4.
Clients -------------------------Fa0/0 SWITCH Fa0/1 -------------------------- Fa0/0 FIREWALL
                                                    Fa0/2
                                                    Ironport
Richard,
You've got it right, either way.  If you put it in duplex, you echo everything from Fa0/1 to Fa0/2.  If you go "Simplex", echo traffic leaving Fa0/1 (on the way to the firewall) Fa0/3, and incoming traffic to Fa0/4.  On a busy network the duplex port on the Ironport could get overloaded...
I'd probably put all of the "security" stuff on a seperate VLAN so that any broadcasts on the client network don't add to the load.
Ken
Richard,
Ken
Thanks.
A follow up question, do i need to configure a span port for this to work? or do I just need to plug it in without any configuration on the switch?
This is for tap and duplex mode. what additional configuration do I need to configure on the switch for this to work.
Yes you need a span port. Span the port that the firewall is connected to to the port T1 is connected to.
