Max Connections for S670 vs S695
CBut
I'm trying to find out the max connections that you can have on both S670 and a S695.
I've had a look at spec sheets etc and I found a reference to 100K connections for the 670 but I was trying to find a more exact number.
We currently have the S670 in place and will be upgrading the S695 later this year so I'm trying to work out if there is any difference in the max connections either can use.
I'm also trying to find out the max connections per unique IP?
Is there a way to pull these numbers from the WSA through CLI or other means?
Thanks.
0 Replies 0
