04-23-2021 10:57 AM
I am facing issue with MS Teams over MAC system. After installing Cisco Any Connect Umbrella Client & configured web Policy, MS Teams stopped working. It is asking for sign in and not getting through. Done the combinations with policy but no luck.
MAC OS - Big Sur, version 11.2.3
Anyconnect secure mobility client version -- 4.10.000093
Anyone facing this issue??
Cisco TAC told me, after new version of MAC OS, this will resolve.
09-06-2023 11:58 AM
I am suspecting this is an issue with split tunnel in use. This is no issue related on AC/SC version nor OS version. This behaviour is challenging me for now.
09-12-2023 01:49 AM
It is definitely, for my case, NOT any kind of OS issue nor AC/SC issue. Just misconfiguration.
I've set:
Along with the networks that has to be tunneled and created 'Custom attribute' list to include my FQDNs that definitely has to be tunneled.
Source I have found:
Step 1 |
Define the custom attribute type in the WebVPN context with the following command: anyconnect-custom-attr dynamic-split-exclude-domains description dynamic split exclude domains |
Step 2 |
Define the custom attribute names for each cloud/web service that needs access by the client outside the VPN tunnel. For example, add Google_domains to represent a list of DNS domain names pertaining to Google web services. The attribute value contains the list of domain names to exclude from the VPN tunnel and must be in comma-separated-values (CSV) format using the following as an example:anyconnect-custom-data dynamic-split-exclude-domains webex_service_domains webex.com, webexconnect.com, tags.tiqcdn.com |
Step 3 |
Attach the previously defined custom attribute to a certain policy group with the following command, executed in the group-policy attributes context:anyconnect-custom dynamic-split-exclude-domains value webex_service_domains |
