Pass HTTPS traffic via a port other than 443 WSA
Sakun Sharma
Level 5
Level 5
I need to pass an HTTPS traffic to a webmail server which is hosted on port 2096. When I tried policy trace in WSA it gives me
"Blocked attempt to HTTP CONNECT over port that is not configured"
URL trying to access - https://r10-sydney.webserversystems.com:2096/
Any help, how to pass this traffic through WSA - AOS-8.0.7.
kushsriva
Level 6
Level 6
If you need the WSA to listen to any non-standard ports you would need to add those ports to the WSA so that it will listen to it.
So please try the following steps:
1). Log into the GUI -> Security Services -> Web Proxy -> Edit settings -> add
port 2096 to the HTTP Ports to Proxy:.
2). Add the port 2096 to the connect ports belonging to the access policy.
 Web Security Manager -> Access Policy ->  Column 'Protocols and User
Agents' which belongs to the Access Policy.
Click on it and it will expand. You will see HTTP Connect ports and add port 2096 to it -> submit and commit your changes.
Kush
Thank you. It worked when i added port 2096 in Protocols and User Agents Settings of that Access Policy.
Sakun
