Proxy denying connection but not giving reason
flyerhawk
We are trying to connect to our slack instance but we are getting the following error..
Sep 5 19:02:40 host SyslogAccess: Info: 1504638160.662 4 10.137.144.175 TCP_DENIED/407 0 CONNECT tunnel://xxxx.slack.com:443/ - NONE/- - OTHER-NONE-VPN_Users-NONE-NONE-NONE-NONE <-,-,-,"-",-,-,-,-,"-",-,-,-,"-",-,-,"-","-",-,-,-,-,"-","-","-","-","-","-",0.00,0,-,"-","-",-,"-",-,-,"-","-"> -
Why am I not getting any details on why it is denying the connection?
balaji.bandi
Check the logs settings, depends on how you configure your log settings.
BB
BB
karajulu1
As per the access logs - TCP_DENIED/407 mean, it needs user authentication for allowing it in the proxy.
Are you accessing this via any application or Web browser ?
If its an application - please check the proxy configuration to add user ID and password for proxy auth.
Note : Some cases you might notice TCP_DENIED/407 and followed by TCP_MISS/200 - then that traffic is allowed in the proxy.
