Sophos AV max scanning size / timeout
m.zoettlein
I haven't found any changeable settings for max. scanning size or scanning timeout on a S160 v7.1.3 with Sophos AV.
In the GUI under "Security Services-->Anti-Maleware"  it shows  "Object Scanning Limits: Max. Object Size:  32 MB".
I'm not able to change it. This parameter seems not to belong to the Sophos AV.
I can change it only after enableing Webroot or McAfee first.
The CLI has no commands for adjusting AV settings.
How can I control the max. scanning size or scanning timeout with Sophos-AV?
Has it fixed values for it?
Does anyone have an idea, how it works?
Kind regards,
Manfred
tidavids
With administrator rights, the value should be editable.  The object size is applied to all scanners which have been licensed and enabled on the appliance.
~Tim
