Stable IOS for Cisco WSA and SMA
Asfandyar70754
Hey guys,
So I am deploying Cisco WSA 395 and SMA 395 and I wanted to know stable version for both of these appliance as I am looking to upgrade them first and then start to configure them.
I went on Cisco's download but there was no mark for recommended version.
balaji.bandi
14.X is the latest.
the appliance give you direction what version to upgrade next level.
make sure SMA is compatable with WSA for to manage.
BB
amojarra
you can check the compatibility matrix for WSA and SMA  from here:
Compatibility Matrix for Cisco Secure Email and Web Manager
note that you should check the Configuration Master compatibility as well, which in the document you can find it as CM.
the GD versions are Gold deployment
the MD are maintenance deployment
also you can check the release notes before upgrading to see the known bugs and fixed bugs
Cisco Secure Web Appliance - Release Notes - Cisco
++++   If you find this answer helpful, please rate it as such  ++++
Amirhossein Mojarrad
