Umbrella Roaming Client nslookup
stanislav.pilat
Frequent Visitor
Frequent Visitor
Hey guys,
I'm testing the Umbrella with 14 days trial and noticed that nslookup feature on windows machine shows my local DNS server as the source of DNS answer even for external domains - I thought that DNS requests to external domains are directly forwarded to Umbrella DNS through the AnyConnect roaming module, which I actually use.
But, in the Umbrella dashboard I can see the requests for external domains (and that's correct), so probably it is working properly and I'm just confused with the result of nslookup.
Could you please clear it up for me?
Thanks in advance.
SP.
2 Accepted Solutions
Shinpei Kono
AnyConnect does not override DNS setting which is assigned statically or via DHCP when DNS protection via roaming module is enabled, and it is still looked up for local search domains and whitelist. Nslookup command without name server option then just directly reaches the DNS server configured there instead of redirecting the request to AnyConnect(and OpenDNS public resolvers). The Umbrella dashboard result might have come from name resolutions through browser or pinging etc and probably your setting was working properly.
Tao Yang
It is actually the expected behaviour. The DNS forward of Cisco Anyconnectr Umbrella roaming module is running at kernel level and it doesn't need to change the local DNS settings like the standalone Umbrella roaming client. Please refer to the following KB for more details.
https://support.umbrella.com/hc/en-us/articles/360000429306-Standalone-Roaming-Client-vs-AnyConnect-Roaming-Module
Shinpei Kono
Tao Yang
stanislav.pilat
Frequent Visitor
Frequent Visitor
Thanks guys for your explanation. 😉
