WCCP - WSAS170 Transparent Proxy not redirecting
jeremyt03
Hi All,
I have configured the WSA with WCCP id 1.  I have one realm, one identity, and 4 access groups which match 4 security groups in AD.
Policy trace when going to a blocked category for a particular user seems to work as expected and says request is blocked.  However, the machine lets said users view the site normally instead of blocking.
Looking at tail 1 logs I'm getting nada.  WCCP statistics show no packet redirection.
I have configured the Core switch as follows
ip wccp source-interface Vlan105
ip wccp 1 redirect-list Cisco_Ironport group-list 99
interface Vlan4
 description $DATA_NETWORK$
 ip address 10.10.30.254 255.255.255.0 secondary
 ip address 10.10.10.254 255.255.255.0 secondary
 ip address 10.10.4.254 255.255.255.0
 no ip redirects
 ip wccp 1 redirect out
I also set up the CDA with passphrases that tests fine.
Any idea why redirection isn't happening?  My first thought is the secondary addresses but a CCIE advised that should be okay.  My next step is to remove the secondary addresses from vlan 4 to see if that is causing an issue.  Ideas anyone?????
Tao Yang
If you run "sh ip wccp 1 detail" in your switch, can you find if the wccp has been established between WSA and your switch.
Which platform did you enable the wccp? Here is a KB and hope it helps.
http://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118006-configure-wccp-00.html
