Web pages not opening
Tiyanjane Nyirenda
Frequent Visitor
Frequent Visitor
My WSA 170 has been running for a month now but now web pages are not displaying.
I have configured ISP DNS servers on the WSA and changed to internal and public but am getting no joy.
when i ping a website it is reolving to an ip address. Any idea as to why pages are not opening
Erik Kaiser
Hi Tiyanjane,
You will need to first log into the WSA using putty via ssh. I would test your internet connection using telnet. At the command line if you type telnet then enter the CLI will present you with several network interfaces which you may select to test internet connectivity. Once you have selected the interface it will ask you for a destination. The CLI will also prompt you for a port to use. Use port 80 for the test. Also DNS requests made by the WSA will made by the M1 interface by default.
Sincerely,
Erik Kaiser
WSA CSE
WSA Cisco Forums Moderator
Sincerely, Erik Kaiser WSA CSE WSA Cisco Forums Moderator
