What is required for Cisco WSA SensorBase network to work ?
stephane.walker
Hello !
I would like to know if the Web Security Appliance has to have a public address to receive the data collected by SensorBase network.
Is there any additional requirements ?
Thank you for your answers.
Stephane Walker
donnylee
Hi Stephane,
The WSA will somehow connected to the Internet directly or via a firewall with your external IP address in the egress point.
SensorBase participation is working via URL via wbnp.ironport.com:443
Depending on your routing, you can test if your WSA can reach this URL from its interface.
I hope this helps.
thanks,
Donny
(*If you have received the answer to your original question, and found this helpful/correct - please mark the question as answered, and be sure to leave a rating to reflect!)
donnylee
Hi Stephane,
I hope this helps.
thanks,
Donny
Thank you donnylee.
I made a packet capture to check if there was any traffic to or from wbnp.ironport.com. I saw some https requests from WSA to wbnp but only the https syn frame. I think that I have some firewall issues that block the answers from wbnp.
I will try to fix it.
Stephane Walker
