WSA S170 - slow/disconnection to SSH and web management
ionel.gardais
Our S170 running 8.5.2-027 for Web is very slow to respond using web management interface.
When connecting over SSH, it either not works at all, or on a better case, I'm disconnected after a few seconds. (I got the prompt, can type a few characters and then no more response from S170).
We use separate routing for M1 and P1-P2.
All routes are correctly declared.
Any tips for this ?
Ionel
Atazazuddin Shaikh
Good Morning Lonel
Thanks for reaching out, This is not a normal behavior of the appliance. I would strongly recommend to open a TAC case so we can investigate further by reviewing system logs etc.  and assist you ASAP,
Zack
